How Do Measurement Uncertainties Impact the Calculation of Gravity?
The discussion revolves around an experiment involving the measurement of gravitational acceleration (g) using a steel ball bearing dropped from a height. The participants are examining how measurement uncertainties in time and distance affect the calculation of g, specifically through the formula \( g = \frac{2s}{t^2} \).
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the significance of uncertainties in time and distance measurements, with one suggesting that time's squared term amplifies its impact on the calculation. Others inquire about methods to determine the uncertainty in g and explore the relationship between absolute and percentage errors in the variables.
The conversation is ongoing, with participants sharing different perspectives on the impact of measurement uncertainties. Some have provided mathematical expressions for calculating uncertainties, while others are questioning whether their interpretations align with the original problem's intent.
There is a mention of a mark scheme indicating that either variable's uncertainty could be considered significant if justified correctly. Participants are navigating the complexities of absolute versus percentage errors in their calculations.
trollcast
The experiment set up is a steel ball bearing is held from an electromagnet and above a switch at the bottom. When the electromagnet is switched off a timer starts and stops when it hits the switch.
The height from the bearings initial position to the switch is measured.
These 2 measurements are then used to calculate g using the formula, $$g=\frac{2s}{t^2}$$
Which of your 2 variables uncertainties is the most significant in determining a value for g?
I said the time taken as in our equation its squared whereas the distance is only multiplied by 2 so any error in the value will be magnified more.
However the mark scheme says either is correct given a logically and scientifically correct reason.
Given that equation, how would you determine the uncertainty in g?
The uncertainty of g would be equal to $$ s / 2t $$
Where s and t are the uncertainties of the same variables.
g = 2s/t2
dg = ∂g/∂s ds + ∂g/∂t dt
So the absolute error dg is
dg = 2/t2 ds due to an absolute error ds, and
dg = -4s/t3 dt due to an absolute error dt.
However, if we're talking percentage errors,
dg/g = 2t-2/2st-2 ds = ds/s and
dg/g = -4st-3/2st-2 dt = -2dt/t.
Thus a percentage error in t is twice as bad as a percentage error in s. I don't know if that's what the problem was asking for ...
  • · Replies 16 ·
