Continuity of a complex function defined on the union of an open and closed set
The discussion revolves around the continuity of a complex function defined on the union of an open set and a closed set, specifically examining the implications of continuity on subsets of the complex plane.
  • Conceptual clarification, Assumption checking, Exploratory
  • The original poster attempts to prove the continuity of the function based on the continuity of its restrictions to open sets. They express uncertainty about providing an example where continuity fails when one set is not open.
  • Some participants question the implications of using the complex logarithm, noting potential discontinuities and considering specific sets like the upper and lower half-planes.
  • Another participant suggests exploring the scenario where the sets are disjoint and the function is constant on each set.
The discussion is active, with participants exploring different aspects of the problem and raising questions about the continuity of functions defined on various subsets. Hints have been provided to guide the exploration of examples and theoretical implications.
The original poster mentions feeling unprepared for the problem-solving nature of the exam, indicating a potential gap between theoretical understanding and practical application.
ridethespiral
(i) Let U and V be open subsets of C with a function f defined on [tex]U \cup V[/tex] suppose that both restrictions, [tex]f_u \mathrm{and} f_v[/tex] are continuous. Show that f is continuous.
(ii) Illustrate by a specific example that this may not hold if one of the sets U, V is not open.
Now I'm pretty sure I can prove the first part. As, since f is continuous on U and V then there exists a [tex]\delta_1[/tex] and on U there will be a [tex]\delta_2[/tex] and then taking the minimum of these will put [tex]|f(z) - f(w)| < \epsilon[/tex] for all epsilon. This works because U and V are open, as it ensures that for each w, there will be a delta disc such that z is in either U or V.
I'm pretty stumped as to an example for the second part. I think I get why it may not hold if U or V is not open, as there will not always be a delta disc around a point in a closed set which is completely contained in that set. But I can't think of a way to use this to arrive at an example.
Hint: complex logarithm
Hmm, I'm not really sure how to use the logarithm. Is it because if you take the principal logarithm, there will be a discontinuity in the principal argument going from -π to π? So if you take the logarithm defined on [tex]\mathbb{C} \backslash {(-\pi, \pi]}[/tex] then the set isn't open. Or perhaps, take U to be the upper half plane and V to be the lower, and the principal argument will be discontinuous? I'm not sure if this is making sense.
I'm confusing myself now. Our lecturer taught this module from a theoretical point of view but decides to make the exam this type of problem solving, which he hasn't really prepared us for. Thanks for any help.
Hint: Consider what can happen if [itex]U[/itex] and [itex]V[/itex] are disjoint and [itex]f[/itex] is constant on [itex]U[/itex] and constant on [itex]V[/itex].
  • · Replies 27 ·
