Impulse Help: Solving a Tennis Ball Problem
  • Thread starter Thread starter Jayhawk1
    Impulse
The discussion revolves around a physics problem involving impulse and momentum related to a tennis ball striking the ground and rebounding. The scenario includes specific parameters such as mass, speed, and angle of impact and rebound.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the definition of impulse and its relation to momentum, with some questioning how to apply the angles involved in the problem. Others suggest decomposing the velocity vector into components to analyze momentum transfer.
The discussion is ongoing, with participants offering guidance on key concepts and encouraging deeper understanding of impulse and momentum. There are multiple lines of reasoning being explored, particularly regarding the role of angles and vector decomposition.
Some participants express uncertainty about how to handle the angles in the problem, indicating a potential gap in understanding vector components in the context of impulse.
Jayhawk1
Impulse help!
A 0.09 kg tennis ball with a speed of 43.2 m/s strikes the ground at a 45.4 degree angle and rebounds with the same speed and the same angle (see the figure below). What is the magnitude of the impulse given to the ball by the ground?
Does anyone have any clue?? I sure don't.
Impulse = change in momentum / time.
Guess you can start by finding dP
Jayhawk,
This isn't just some random problem designed to make you do some math. Ask yourself, "what key concept about physics that I am supposed to learn about is being tested here?" Do you know the definition of impulse? (If you don't, then learning it would be a good place to start, considering that's what you're being asked to calculate!) Furthermore, have you heard of the impulse-momentum theorem?
I don't know what to do with the angles...
Use the geometry and the property of vectors to be decomposed after orthonormal coordinates.In your case,one component from the initial vector will not transfer momentum at all,while the other will transfer it all.
Daniel.
  • · Replies 19 ·
9K
  • · Replies 24 ·
