| New Reply |
Are the number of microstates of a gas just equivalent to pressure |
Share Thread | Thread Tools |
| Jan6-13, 08:01 AM | #1 |
I am quite confused about this area.
First entropy does not contain any reference to volume. So if we can theoretically set the entropy of A and B gas samples as the same but in different volumes. If A is in a larger volume it would be able to exhibit a larger number of microstates? Yet the Boltzman equation gives the same result for both as it also ignores volume. I would also be interested to know if the concept of microstates is actually at all useful, or is it just a bystander in real world physics. Thanks |
| Jan6-13, 09:48 AM | #2 |
Mentor
| Jan6-13, 10:08 AM | #3 |
So E, S and T are all the same, but Boltzman states should be different. (Lets assume radiatively reflective housing to eliminate infrared heat loss.) |
| Jan6-13, 10:57 AM | #4 |
Mentor
Are the number of microstates of a gas just equivalent to pressureBut then you get a different number of microstates, and a different entropy. |
| Jan7-13, 01:42 AM | #5 |
| Jan7-13, 05:53 AM | #6 |
Sorry for the basic confusion there. I has always imagined microstates visually - making the volume and locations of the particles an aspect of the calculations, whereas it is actually just about the distribution of energies according to one source I have just read and not about the volume. And it follows that this is true from:
Entropy = energy over temperature - nothing to do with volume Entropy = k log.w - nothing to do with volume either (Though not 100% sure how W is assessed) (If we are being finicky about it, in reality, the volume does make a difference due to gravitation reducing the maximum energy probable away from the earth.) An important exception is if we vapourise a few hunderd molecules of gold - there is the likelihood of, on average, a nice normal distribution of energies in the atoms in a confined space, however if we distribute these molecules in a sufficiently large space wherein they will not collide evidently they will retain their initial energies. So the law of entropy breaks down here. |
| Jan7-13, 07:17 AM | #7 |
I have just been thinking about this a little more and it turns out that volume does make a difference to the number of available microstates as multiatom collisions become less likely in a less dense substance wherein the momentum of two atoms in vector x might add up to produce a high value otherwise rarely produced (?).
| Jan7-13, 08:05 AM | #8 |
Mentor
More volume -> more states for the particles at same energy -> more microstates for a given temperature. It is as simple as that. |
| Jan7-13, 09:30 AM | #9 |
Brilliant; thanks; that is a lot clearer now.
| Jan7-13, 11:27 AM | #10 |
| New Reply |
| Thread Tools | |
Similar Threads for: Are the number of microstates of a gas just equivalent to pressure
| Firmi-Dirac Stats. - Calculate number of microstates. | Advanced Physics Homework | 1 | ||
| Introductory Statistical Mechanics - counting number of microstates | Advanced Physics Homework | 3 | ||
| photons and and equivalent number of atoms on gravity | Special & General Relativity | 1 | ||
| Definition of the number of microstates accessible to a system | Classical Physics | 2 | ||
| Equivalent number of flops for quantum computers? | Engineering, Comp Sci, & Technology Homework | 0 | ||
