| New Reply |
Advice on approcah for humidity conversions in c# |
Share Thread |
| Jan9-13, 11:15 AM | #1 |
Hello all,
First off, I would just like to say hello, as I am a new member :) I was hoping for some advice on implementing humidity conversions in code. I have spent about 4-5 days trawling the internet for helpful psychometric functions to help convert relative humidity to absolute humidity and back. Despite numerous attempts, I have failed in implementing anything that will output anything but garbage values. While I may appreciate some of you are thinking that this is a programming problem, i assure you it isn't. The only variables I have to play around with are the dry bulb temperature of the air, the altitude, the pressure at that altitude and the absolute humidity for the relative humidity calculation ( and vice versa ). I do not have the dew point. At this juncture, I would be happy to use something like the Sonntag or Magnus formula. As a software engineer, this is very much out of my league. Thus, if anyone could give some advice on appropriate approaches, I would be most appreciative. Best, A Programmer |
| PhysOrg.com |
engineering news on PhysOrg.com >> Multiview 3-D photography made simple >> Giant 3-D printed bugs shed light on insect anatomy >> A microphone that listens with light |
| Feb4-13, 05:53 PM | #2 |
Hello, collegue :)
//Saturated vapor pressure knowledge (by Sonntag or Magnus formula) is quite enough. double RelativeHumidity(double AbsoluteHumidity, double Temperature) { return AbsoluteHumidity / SaturatedVaporPressure(Temperature); } |
| Feb5-13, 04:35 AM | #3 |
Hi Graniar,
Thanks very much for the help. I got it cracked in the end; i used the exact same formula you quoted to get AH, and i just did a recursive search with an increasingly narrow search to provide a decently accurate estimation for the RH. Thanks again, A_Programmer |
| New Reply |
Similar discussions for: Advice on approcah for humidity conversions in c#
| ESD and Humidity | Electrical Engineering | 2 | ||
| Humidity of my lab WAY too low | General Engineering | 7 | ||
| what is the relation between humidity and temperature? | Mechanical Engineering | 1 | ||
| Humidity and using a telecscope | General Astronomy | 10 | ||
