Millikan Oil Drop Experiment Question
The problem involves the Millikan oil drop experiment, where an oil drop is subjected to an electric field between two plates. The objective is to determine the charge on the oil drop based on its mass, acceleration, and the potential difference between the plates.
  • Participants discuss the calculations related to the forces acting on the oil drop and the resulting charge. Questions arise regarding the quantization of charge and whether the calculated charge corresponds to an integer number of electrons.
Some participants express agreement with the calculations presented, while others raise questions about the nature of charge quantization and the implications of obtaining a non-integer result. The discussion explores the concept of experimental uncertainty and its impact on the results.
There is mention of additional factors that could affect the accuracy of the experiment, such as air viscosity and buoyant forces, which are not fully addressed in the original problem statement.
Kennedy111
A 1.50 x 10^-14 kg oil drop accelerates downward at a rate of 1.80 m/s^2 when placed between two horizontal plates that are 9.40 ch apart. The potential difference between the two plates is 980 V. Determine the magnitude of the charge on the oil drop.
m = 1.50 x 10^-14 kg
a = 1.80 m/s^2 (down)
d = 9.40 cm = 9.40 x 10^-2 m
V = 980 V
Fnet = Fg + Fe
Fnet = ma
Fe = Eq
Fg = mg
E = V/d
Fnet = Fg + Fe
Fe = Fnet - Fg
= ma - mg
= ((1.50 x 10^-14 kg)*1.80 m/s^2)) - ((1.50 x 10^-14 kg)(9.81 m/s^2))
= -1.2015 x 10^-13 N
E = V/d
= (980 V) / (9.40 x 10^-2 m)
= 10425.53191 V/m
Fe = Eq
q = Fe / E
= (-1.2015 x 10^-13 N) / (10425.53191 V/m)
= -1.1524592 x 10^-17 C
The charge on the oil drop is approx. -1.15 x 10^-17 C ?
Looks ok to me. Does the charge correspond to an integer number of electrons on the drop?
{Accurate analysis of the Millikan Oil Drop Experiment would take into account the viscosity of the air and the buoyant force acting on the drop, and involves measuring terminal velocities rather than accelerations. See http://en.wikipedia.org/wiki/Oil_drop_experiment . But what you did looks correct based on the information given.}
If I divide that charge by 1.60 x 10^-19 C I get 72.0207 electrons. Does it have to be a whole number?
Yes! At least if the data is good! That's one reason the experiment is considered a classic. Millikan found the net charge of the drops to be "quantized" as integer multiples of a fundamental amount of charge e. 72.02 is close to an integer. The discrepancy can be chalked up as "experimental uncertainty in the data".
[EDIT: Millikan reported net charges on the drops ranging from 1*e to 136*e. See http://www.aip.org/history/gap/PDF/millikan.pdf ]
Okay, I understand! Thank you for your help!
  • · Replies 52 ·
