Gradient and Laplacian of three functions
The discussion revolves around the mathematical concepts of gradient and Laplacian in the context of Smoothed Particle Hydrodynamics (SPH). The original poster presents three specific functions related to SPH and seeks assistance in calculating their gradient and Laplacian, expressing a lack of familiarity with multi-variable calculus.
  • The original poster attempts to understand the gradient and Laplacian as derivatives of the presented functions, questioning whether the magnitude operation simplifies the problem to one dimension. They express a desire for the equations rather than the procedures involved in deriving them.
Some participants provide guidance on the nature of the gradient and Laplacian, clarifying that the gradient is vector-valued and the Laplacian is scalar-valued. There is an acknowledgment of the original poster's intent to implement these equations in code, and further exploration of the functions' gradients and Laplacians is ongoing.
The original poster notes that their inquiry is not for homework but for independent study, which raises questions about the appropriateness of the forum for their request. There is a mention of stability issues related to one of the functions, indicating a need for completeness in the calculations.
sciwizeh
Hello, I've been reading up on Smoothed Particle Hydrodynamics. While reading some papers I found some math that I do not know how to do because I never took multi variable calculus. I need the gradient and laplacian of all three of the following functions ( h is a constant ):
Wpoly6(r,h)=[itex]\frac{315}{64\pi h^{9}}\begin{cases}<br /> (h^{2}-|r|^{2})^{3} & 0\leq r\leq h \\ <br /> 0 & \text{ otherwise } <br /> \end{cases}[/itex]
Wspiky(r,h)=[itex]\frac{15}{\pi h^{6}}\begin{cases}<br /> (h-|r|)^{3} & 0\leq r\leq h \\ <br /> 0 & \text{ otherwise } <br /> \end{cases}[/itex]
Wviscosity(r,h)=[itex]\frac{15}{2\pi h^{3}}\begin{cases}<br /> -\frac{r^{3}}{2h^{3}}+\frac{r^{2}}{h^{2}}+\frac{h}{2r} & 0\leq r\leq h \\ <br /> 0 & \text{ otherwise } <br /> \end{cases}[/itex]
note: almost copied the last one wrong, the last term of the top is h over 2r and the other terms are r's over h's
If I understand correctly the magnitude operation makes this an essentially 1 dimensional problem and the gradient is the derivative and the lapracian is the second derivative. Am I right in this thought? If not what does it mean?
I am very rusty in my calculus, so even if that is true, I would prefer the answers rather than the procedure. The only thing I need in order to translate the papers to an implementation is these 6 more equations.
Gradient and Laplacian operators are covered in multi-variable or vector calculus.
I would start there.
Yes, I know, but I am no longer in school and I never took multi-variable calculus. I also have read the wikipedia page on them and I get the principal, but I don't know how to deal with the magnitude operation, also it's been years since I've done any kind of calculus work so I don't remember much. I also just need the equations to implement in code.
OP said:
If I understand correctly the magnitude operation makes this an essentially 1 dimensional problem and the gradient is the derivative [of a function of the magnitude] and the lapracian is the second derivative. Am I right in this thought? If not what does it mean?
Because this is a homework help forum and you seem reluctant to just answer the question, I want to be clear, this is NOT homework, I'm independently trying to implement smoothed particle hydrodynamics. The papers give the functions above, but most of the formula's use the gradient of them or the laplacian without actually giving them.
Since this is not for homework work, you kind of posted in the wrong forum, but I'll help you out anyway because your intention seems to be in implementing it in code.
Gradient (note that it is vector-valued; you would need to use several variables to implement this in your code; one for each component, or you could use an array/list):
[tex]∇W = <\frac{∂W}{∂r},\frac{∂W}{∂h}>[/tex]
Laplacian (scalar valued, you only need one variable to store the Laplacian):
[tex]ΔW = ∇ \cdot ∇W[/tex]
BiP
But it is:
Hurkyl said:
Please post any and all homework or other textbook-style problems in one of the Homework & Coursework Questions forums, whether the problem is part of one's assigned coursework or just independent study. And, before posting, read the section entitled "Homework Help" in the PF Global Guidelines.
Technically this would be under the heading of "just independent study." (No?)
Anyhow, h is actually a constant, the vector is r, so it would be:
[itex]∇W = <\frac{∂W}{∂r_x},\frac{∂W}{∂r_y},\frac{∂W}{∂r_z}>[/itex]
correct?
Digging through more papers I've found: (note, I've also changed r to r with arrow to better indicate vector valued)
[itex]W_{poly6}(\vec{r},h)=\frac{315}{64\pi h^{9}}\begin{cases} <br /> (h^{2}-|r|^{2})^{3} & 0\leq |r|\leq h \\ <br /> 0 & \text{ otherwise } <br /> \end{cases}[/itex]
[itex] \bigtriangledown W_{poly6}(\vec{r},h)=(-6)\frac{315}{64\pi h^{9}}\begin{cases} <br /> (h^{2}-|r|^{2})^{2} \begin{pmatrix}<br /> r_{x}\\ <br /> r_{y}\\ <br /> r_{z}<br /> \end{pmatrix} & 0\leq |r|\leq h \\ <br /> \mathbf{0} & \text{ otherwise } <br /> \end{cases}[/itex]
[itex]\bigtriangledown^{2} W_{poly6}(\vec{r},h)=\frac{315}{64\pi h^{9}}\begin{cases} <br /> -18(h^{2}-|r|^{2})^{2}+24|r|^{2}(h^2-|r|^2)<br /> & 0\leq |r|\leq h \\ <br /> 0 & \text{ otherwise } <br /> \end{cases}[/itex]
[itex]W_{viscosity}(\vec{r},h)=\frac{15}{2\pi h^{3}}\begin{cases} <br /> -\frac{|r|^{3}}{2h^{3}}+\frac{|r|^{2}}{h^{2}}+\frac{h}{ 2|r|} & 0\leq |r|\leq h \\ <br /> 0 & \text{ otherwise } <br /> \end{cases}[/itex]
[itex]\bigtriangledown W_{viscosity}(\vec{r},h)=\frac{15}{2\pi h^{3}}\begin{cases} <br /> -\frac{3|r|}{2h^{3}}+\frac{2}{h^{2}}+\frac{h}{ 2|r|^3}<br /> \begin{pmatrix}<br /> r_x\\ <br /> r_y\\ <br /> r_z<br /> \end{pmatrix}<br /> & 0\leq |r|\leq h \\ <br /> 0 & \text{ otherwise } <br /> \end{cases}[/itex]
[itex]\bigtriangledown^2 W_{viscosity}(\vec{r},h)=(6)\frac{15}{2\pi h^{3}}\begin{cases} <br /> (\frac{1}{h^3})(h-|r|)<br /> & 0\leq |r|\leq h \\ <br /> 0 & \text{ otherwise } <br /> \end{cases}[/itex]
Are these correct? I sort of get how to get the gradient, but I don't understand the Lapracian at all.
With these equations I could implement what I need to, however one paper mentions a stability issue if the third W function is not used. So for completeness I need the gradient and lapracian of:
[itex] W_{spiky}(\vec{r},h)=\frac{15}{\pi h^{6}}\begin{cases} <br /> (h-|r|)^{3} & 0\leq r\leq h \\ <br /> 0 & \text{ otherwise } <br /> \end{cases}[/itex]
