Special Relativity of rocket relative to you
The discussion revolves around a problem in Special Relativity involving a rocket traveling at a significant fraction of the speed of light (0.6c) and a missile fired perpendicularly at 0.7c. Participants are exploring how to determine the speed and angle of the missile as observed from a stationary frame.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of Lorentz transformations for velocity and express confusion regarding the reference frames and the variables involved, such as "ux", "ux'", and "v". There is an attempt to clarify the relationship between the rocket's speed and the missile's speed in different frames.
Some participants have offered guidance on how to approach the problem by suggesting starting with the missile's equation in the rocket's frame and using Lorentz transformations to find the equivalent speed in the observer's frame. However, confusion remains regarding the definitions of the variables and the reference frames.
Participants are grappling with the definitions of variables and the setup of the problem, indicating a need for clearer differentiation between the speeds of the rocket and the missile. There is an acknowledgment of the complexity of the Lorentz equations, which adds to the confusion.
tombarrtt
Studying Special Relativity at the moment, and having a little trouble getting to grips with it. I've got stuck on this question, and was wondering if anyone could clear it up for me?
Here's the question:
"A rocket is traveling at 0.6c, v, along the x-axis relative to you. It fires a missile in the y-axis (perpendicular to the rocket in the rocket's reference frame) at 0.7c relative to you.
What speed and at what angle to the x-axis do you see the missile travelling?"
I think you have to use the Lorentz transformations for velocity, but I'm not sure.
I think: ux' = (ux-v)/(1-uxv/c^2)
and: uy' = uy/(gamma*(1-uxv/c^2))
I think you have to use the Lorentz transformations for velocity, but I'm not sure. I'm just getting confused with which reference frames to choose for the rocket, and what the variables "ux", "ux'" and "v" are and how to put them in.
welcome to pf!
hi tombarrtt! welcome to pf! :smile:
i think the Lorentz equations for velocity are too difficult to remember :redfae:
start with the equation of the missile in the rocket's frame …
that's x' = 0, y' = u't'
(you don't know yet what u' is, but you do know that the equivalent speed u in your frame is 0.7c)
now use the Lorentz transformation to convert that to your frame, find u, and put it equal to 0.7c …
what do you get? :smile:
Sorry I'm just still really confused. "v" is the x-velocity of the rocket right, so 0.6c? Then what are Ux and Ux'? Is Ux' the transformed velocity into our frame? But then what is Ux, surely that's the same as v?
I'm just so confused by this :/
hi tombarrtt! :smile:
solving maths problems often just involves giving everything sensible names, so that you can clearly see what you're doing
in this case, you need to differentiate clearly between the speed of the rocket and of the missile
so I'm using v for the rocket, and u for the missile :wink:
  • · Replies 35 ·
