Adding Batteries in Series: Explaining Voltage Increase
  • Context: High School
  • Thread starter Thread starter madbear
The discussion revolves around the concept of adding batteries in series and the implications for voltage increase. Participants explore the relationship between electron transfer, voltage, and the chemical processes within batteries, addressing both theoretical and conceptual aspects.
  • One participant questions why voltages would add up when connecting two batteries in series, suggesting that electron transfer might equalize potential differences and result in zero voltage difference.
  • Another participant clarifies that voltage is not the same as electron transfer, emphasizing that voltage represents a potential difference that can exist without current flow.
  • A participant notes that batteries generate a steady electromotive force (EMF) from chemical reactions, which is crucial for maintaining voltage in series connections.
  • One participant expresses confusion about current flow between batteries in series, wondering if a current would occur due to differing potentials, while acknowledging the role of chemical energy in maintaining voltage.
  • Another participant discusses the concept of stray capacitance in circuits, suggesting that current flow in series connections may be limited to charging stray capacitances rather than significant current flow between batteries.
  • A participant introduces a chemical perspective on battery function, explaining the role of half-cells and the necessity of maintaining electrical neutrality within the battery system.
  • One participant reiterates their initial question about the series connection of batteries, emphasizing the need for understanding capacitance in relation to voltage and electron count.
Participants express various viewpoints on the relationship between voltage, electron transfer, and battery function. There is no consensus on the initial question regarding voltage addition in series connections, and multiple competing views remain throughout the discussion.
Some participants reference concepts such as capacitance and the chemical processes within batteries, but these ideas are not fully resolved or agreed upon. The discussion includes assumptions about electron behavior and potential differences that are not universally accepted.
madbear
lets say i got two batteries; first has 200 electrons on plus terminal and 300 electrons on a negative terminal ( so there is 100 electrons difference in potential energy )
and and second battery has 100 electrons on + terminal and 200 electrons on -.
if connected in series +(200e) -(300e)_____ +(100e) -(200e)
why would voltages add up ? wouldn't 100e from - terminal of the first battery be transferred
to + terminal of the second battery making pic look like :
+(200e) -(200e)_____ +(200e) -(200e) making potential difference between + terminal of the first battery and - terminal of the second battery zero ?
Transfer of electrons is current not voltage. To maintain a constant voltage, the difference in "electrons" must remain contant. Voltage is not a transfer of electrons, you can (and commonly do have) a voltage, or potential difference, with no movement of electrons.
Recall that batteries work off of chemical energy -- they typically create a steady EMF generated from that chemical stuff. That's what keeps the electrons doing the right thing, and allows batteries in series to do the right thing. You will find this discussed in more-or-less detail in most any freshman physics text.
Regards,
Reilly Atkinson
Thank you for your help. I am still at lost though. I thought if you connect two
objects with a diffrent number of free electrons by a wire -- there will be current
going from a higher to a lower potential point. So will there be a current going
between the two connected terminals of batteries in series if they differ in potential ?
I do undestand that chemical energy in a battery is what creates and keeps
the voltage at a constant level.
If you hook two battereies up in parallel, then move one of them to a series connection, the only current flow will be to charge up stray capacitances.
The capacitances across the batteries won't contribute to the curreent flow - if you draw the circut out, you should see that any stray capacitance from either of the second batteries's terminals to ground will have to be charged or discharged.
Voltage is energy / charge. The reason that voltages add in a loop is that energy is conserved.
a battery is divided up into two half-cells of ions (positive and negatively charged atoms) in solution, connected by a salt bridge. Both are electrically neutral, so they have the same amount of positive and negative charge, but the half-cell that's the negative terminal has ions that are better at attracting electrons than the half-cell that makes up the positive terminal. Now, both half-cells have to stay neutral, so any charge that leaves the positive terminal is replaced by ions from the salt bridge dissolving into the solution, and a similar situation occurs for the negative terminal.
So I don't know if it helps to talk about the chemistry of a battery, but maybe it's useful or interesting.
You need to study the Capacitor, Q=CV.
You don't know the voltage if all you know is that you have 200 electrons.
You need to know the capacitance, and THEN this doesn't apply to a battery.
  • · Replies 58 ·
  • · Replies 36 ·
  • · Replies 19 ·
