How can you make it go a certain distance?
  • Thread starter Thread starter mizz_melanie
To achieve a target distance of 2.2 meters with a catapult, understanding projectile motion and applying relevant formulas is essential. The launch angle, ideally around 45 degrees, and the initial stretch of the elastic material will significantly influence the distance traveled. Utilizing the standard equations of motion, such as V² = U² + 2as, can help calculate the necessary parameters. Conducting experiments by varying the stretch and recording the resulting distances will provide valuable data for adjustments. Accurate results may be challenging due to sensitivity in angle changes, so thorough testing is recommended.
mizz_melanie
We have to build catapults in school and the teacher wants us to hit targets placed 2-4 meters but to get it to go a certain distance (2.2) How can I do it mathematically (with protectors or measuring length)? What formulas can I use?
- Also the targets will be randomly placed the day i have to shoot it
mizz melanie,
Google is your friend. It can help you find information. Learn to use Google search and you will get new knowledge, satisfaction, and be happier. I entered the search words “calculate distance of projectile” and in 0.49 seconds about 1,140,000 results appeared. Below please find three that you may find useful:
How to Calculate the Distance of a Projectile
Read more:
http://www.ehow.com/how_6357145_calculate-distance-projectile.html#ixzz2HoYg1DQI
http://en.wikipedia.org/wiki/Trajectory_of_a_projectile
http://www.calctool.org/CALC/phys/Newtonian/projectile
Let us know how your project goes. (edit) If you have any doubts or further questions, post them here. Members here are always willing to assist any true searcher for the behaviours found in our natural world.
Cheers,
Bobbywhy
melanie - Have you covered the standard equations of motion yet? I mean equation such as V2=U2 + 2as.
If not then this is probably an experimental exercise. Set up the catapult so it fires the projectile at a fixed angle (say 45 degrees). Then arrange so you can stretch the catapult a controlled amount. Fire off numerous shots with various amounts of initial stretch. Plot a graph for stretch vs distance. Try and get lots of data that covers the likely range (eg 2 - 4m). Then when the teacher tells you the target distance you can look up the stretch required. I suspect it won't be possible to get accurate results. Slight changes to the angle may make a big difference.
If you are familiar with the standard equations then the distance will depend on the initial launch velocity and launch angle. See links Bobbywhy posted. The launch velocity will depend on the properties of the elastic used in the catapult (Google Hookes law).
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
