Solving for Parallel Tangent Lines: A Confusing Example
The discussion revolves around finding the point on the curve defined by the equation y = 1 + 2e^x - 3x where the tangent line is parallel to a given line, specifically 3x - y = 5. Participants are exploring the relationship between the slopes of the tangent line and the given line.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to compare slopes by computing derivatives. There is a focus on determining the slope of the tangent line from the curve and equating it to the slope of the given line.
Some participants have provided guidance on the correct approach to finding the slopes and equating them. There is acknowledgment of initial confusion regarding the calculations, but a productive direction has emerged as participants clarify their understanding of the derivatives involved.
There is mention of potential confusion regarding graphical interpretation and the need for visual aids to better understand the relationship between the curve and the tangent line.
zenity
I'm kinda stuck on this question... my text gives me a simple example, but it's far from enlightening. Just wondered if I could get some help!
"At what point on the curve y = 1 + 2e^x - 3x is the tangent line parallel to the line 3x -y =5?"
Would I just need to simply compare the slopes?
I found the derivative of the curve: y'= 2e^x - 3
So I suppose you just set 2e^x = 3... then you get x = ln(3)/2 ?
Thanks~
parallel means same slope, so u found [tex]\frac{dy}{dx} = 2e^x - 3[/tex]
[tex]y=-5+3x, \frac{dy}{dx} = 3[/tex]
[tex]3 = 2e^x - 3[/tex]
[tex]3 = e^x[/tex]
[tex]ln(3) = x[/tex]
Oh, so I had to compute the derivatives for both slopes, then compare them? Interesting... thanks! I have to digest this info now.
-------> Should be -----> 2e^x - 3 = 3 -----------> x = ln(3)
Thanks~
zenity --
Your original approach was CORRECT. You just made the careless error shown above. Method is to determine slope of the line (compute dy/dx of the line OR determine by inspection (like you did) from the line's {y = mx + b} equation that the slope is "3") and then to equate this value to the curve's tangent slope (found by differentiating the curve's equation like you did).
so the point would be... ( ln(3), 7-3ln(3) ) ?
I'm just a bit confused graphically.
zenity said:
so the point would be... ( ln(3), 7-3ln(3) ) ? <----- CORRECT
Your answer is CORRECT. If helpful, sketch the graph to better understand the math. (Or use a graphing calculator.)
  • · Replies 18 ·
