New Reply
Furnace flame- light intensity
Share Thread Thread Tools
Jan16-13, 07:58 AM   #1
Hi Guys,
A basic oxygen furnace is very large 400 ton vessel that steel is refined in. during the refining process oxygen is blown into the steel. during this process there is a flame at the mouth of the furnace, this is what im interesting in. during the process the flame changes in size and intensity. I want to be measure the intensity of the flame by using a camera to capture an image then use some c#/matlab code to calculate the intensity based on the RGB array of the image. will this work to give an indication of the relative intensity of the flames ? or have a missed the boat? can you clever people please help?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
>> Researchers use light projector and single-pixel detectors to create 3-D images
Jan20-13, 09:33 PM   #2
You probably want to use a fairly thick filter. CCDs are fairly linear, and in a camera, the lens is usually sized so that other than aiming directly at the sun, the data can be handled. Technically, the light you are trying to measure is not quite as bright as the sun's surface. However the atmosphere knocks the solar intensity down a significant amount.
The best filter for your application is going to reduce the light by several orders of magnitude. You also need to consider the heat absorbed by the filter all up and down the spectrum. This is why I recommend a reflecting filter. The "extra" light from the mirror surface won't contaminate your reading all that much. (And if you care more for cheap than precision you can take almost any pocket mirror and remove the black paint on the back. ;-)
Jan20-13, 11:18 PM   #3
Engineering 2012
Recognitions:
Gold Membership Gold Member
Interesting project.
the flame detectors in our oil/gas fired boilers used a UV sensor and measured the AC component or 'flicker' of the resulting signal.
But that was forty years ago. Surely they've become more sophisticated.
Same outfit is still in business. This instruction manual from them gives an intro to optical flame detection, see around page 14-15. Probably you're aware of them, though...
http://66.18.210.80/manuals/Fireye/SERVICE%20MANUAL.pdf
Jan21-13, 01:09 AM   #4
@ eachus - Thank you :) , Thats just the sort of thing I had no knowledge of. I am definitely going to give it a try, will let you know how it goes.
@jim- Thanks Jim, that would work, however cost is a factor, so I'm trying to get a cheap 'home-made' solution ;-)
New Reply
Tags
flame, furnace, intensity, light
Thread Tools
Similar Threads for: Furnace flame- light intensity
Thread Forum Replies
How to calculate flame length inside a Fire-Tube boiler furnace? Mechanical Engineering 0
Spatial Light Modulator to remove high intensity light General Physics 1
Why does light intensity decrease when light passes through a glass block? General Physics 7
Difference between flame and light General Physics 1
Intensity of light / measuring wavelength of light Introductory Physics Homework 2
