Multivariable function notations
  • Context: Graduate
  • Thread starter Thread starter medwatt
    Function Multivariable
The discussion revolves around the notations and interpretations of multivariable functions, particularly focusing on the relationships between variables in expressions like z = f(x, y) and the implications of introducing additional variables. Participants explore the meaning of gradients in different contexts and how these relate to surfaces and curves in three-dimensional space.
  • One participant suggests that z = f(x, y) represents a function of three variables, with x and y being independent, leading to confusion when introducing additional variables like z in different contexts.
  • Another participant argues that z = f(x, y) is merely an equation in three variables and emphasizes that the dependency of variables is a matter of convention.
  • Participants discuss the gradient of functions, with one noting that the gradient ∇f is normal to a curve defined by f(x, y) = C, while another highlights that this gradient may not necessarily be normal to the surface unless specific conditions are met.
  • There is a question raised about whether a vector normal to a curve on a surface can also be considered normal to the surface itself, leading to further exploration of conditions under which this holds true.
  • Clarifications are made regarding the representation of gradients in three-dimensional space and the implications of casting vectors to fit this context.
Participants express differing views on the interpretation of variable dependencies and the implications of gradients in relation to surfaces and curves. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight the importance of clarifying definitions and conventions used in multivariable calculus, particularly regarding the roles of variables and the interpretation of gradients in different dimensional contexts.
medwatt
Hello,
I've been having some trouble getting some notations straight and hence my question.
Usually when I see f(x,y) it means to me there is some variable z produced for any combination of x and y in the domain of the function. So, z=x^2+y^2 I imagine as a paraboloid.
So z=f(x,y) ... is a function of three variables with x and y being independent . . . but sometimes I see u=F(x,y,z)=f(x,y)-z . . . all of a sudden it seems as though z has suddenly become independent and there are now four variables.
I hope someone can clarify my mishap in reading functions properly or provide me with a source where I can read all various ways functions are written.
Thank You...
EDIT: Reason why I raised this question.
I have a function z=ln(xy^2).
1. First consideration . . .
If z=f(x,y) then : F(x,y,z)=f(x,y)-z
Hence grad(F)=<1/x,2/y,-1> . . . At point(1,1,0) . . . grad(F)=<1,2,-1> . . . where grad(F) is a vector normal to the surface at that point
2. Second consideration . . .
If z=f(x,y) then I can also do . . grad(z)=<1/x,2/y> . . . At point(1,1,0) . . . grad(F)=<1,2> . . . which is also normal to the surface with a rising rate of modulus(<1,2>)
So I interpreted the problem in two ways and I had two seemingly similar representations of normal vectors to the curve with one having an extra term that I cannot interpret.
Nope, it's an equation in 3 variables. We really don't care too much about what's a function of what here.
Some clearing up should be done by explaining what exactly we mean by a graph. A graph of some equation (not always z=f(x,y) for some f) is the set of all points (x,y,z) that satisfy the equation. Once we clear that up, it shouldn't really matter what's dependent on what. It's just convention that we usually try to write z=f(x,y).
The second is [itex]\nabla f[/itex] in two-dimensional space. It's normal to the curve [itex]f\left(x,y\right)=C[/itex], where C is a constant, not to the surface. The first is [itex]\nabla\left(f\left(x,y\right)-z\right)[/itex], where z is some new variable, independent of x and y (unless we're only looking at the gradient when we're on the surface,) which is our third variable if we're taking the gradient in three-dimensional space.
If ∇f is normal to a curve and the curve lies on the surface . . . shouldn't that mean the vector is also normal to the surface because after all a vector only acts at a point ?
Only if the surface is vertical, for instance, we could consider the plane [itex]x=z[/itex]. For given z, the gradient of the function f, where [itex]z=f\left(x,y\right)[/itex], is [itex]\left\langle1,0\right\rangle[/itex], which sticks out from the plane, but not perpendicular to it.
Another thing to note is that [itex]\left\langle1,0\right\rangle[/itex] doesn't really mean anything in a three-dimensional example. So, for this to make sense, we'd "cast" it (to use the programming term) to [itex]\left\langle1,0,0\right\rangle[/itex] for three-dimensional problems. Note that this is just an arbitrary choice of "cast" that's the most intuitive.
  • · Replies 17 ·
  • · Replies 32 ·
