Two air cylinders acting against each other
  • Thread starter Thread starter djc9273
    Air Cylinders
This discussion focuses on designing a system using air cylinders to achieve four precise positions: 0 inch, 1 inch, 2 inch, and 3 inch. The main driving cylinder, referred to as Cylinder A, has a stroke of 3 inches and a bore of 25mm. Two additional cylinders, B and C, with strokes of 2 inches and 1 inch respectively and a bore of 32mm, are utilized as hard stops to control the position of Cylinder A. Concerns were raised about potential drift in positions 2 and 3 due to pressure equalization issues, suggesting that pop-up stops actuated by solenoids may provide a more reliable solution.
  • Understanding of pneumatic cylinder mechanics
  • Knowledge of stroke length and bore size implications
  • Familiarity with pressure equalization in pneumatic systems
  • Basic principles of solenoid operation in automation
  • Research pneumatic cylinder configurations for precision positioning
  • Learn about pressure equalization techniques in pneumatic systems
  • Explore the design and implementation of pop-up stops using solenoids
  • Investigate the effects of bore size on force distribution in pneumatic systems
Pneumatic system designers, automation engineers, and anyone involved in precision control applications using air cylinders.
djc9273
I'm trying to design a system in which one air cylinder (single piston) can reach 4 repeatable positions. Multi-piston cylinders won't work because I need fine adjustment in the position of each of the four stages. The four positions are at 0 inch, 1 inch, 2 inch and 3 inch.
My idea was to have one cylinder as the main driving cylinder (let's call this cylinder A with a stroke of 3 inches and bore of 25mm), and two cylinders (theoretically coaxial with Cylinder A, but acting in a the opposite direction) with a stroke of 1 and 2 inches respectively (and a bore of 32mm). Let's call these cylinders B (2 inch stroke) and C (1 inch stroke).
My idea is to use the cylinders B and C as "hard stops" to obtain an adjustable position that Cylinder A can extend to (through the use of a through piston rod with a fine adjustment screw on the back)
There will be four positions, and in order to reach position 1 & 4, Cylinder A would be extended or retracted as usual. To reach position 2, Cylinder B would be extended and cylinder A would be Extended. This way the rod of cylinder A would be driving against the rod of cylinder B (which has a larger bore, same pressure). And likewise for position 3.
My concern is how "hard" these hard stops would be in this situation. With the same pressure throughout the system, the force in Cylinders B & C would always overcome Cylinder A, but will there be any drift in the position once the system "settles" at positions 2 & 3?
I think rather than using opposing air pistons you're better off using pop-up stops for the main piston using solenoids. Depending on where you want it to stop, actuate the bump stop for the position you want. As you say, opposing air pistons could have some position variation if there are pressure equalization issues, and they will have some settling time as well.
  • · Replies 19 ·
  • · Replies 45 ·
  • · Replies 39 ·
  • · Replies 33 ·
