Solving a Resistance Question Problem: Nichrome Heating Element
  • Thread starter Thread starter ToxicBug
    Resistance
The problem involves calculating the final temperature of a Nichrome heating element in a toaster, which has a resistance of 80.0 ohms at 20.0 degrees Celsius. The initial current is 1.50 A, decreasing to 1.30 A as the element heats up. The final temperature is determined to be 313°C, as the resistance of Nichrome increases with temperature, affecting the current. The calculations must ensure correct values for resistivity ("rho") at 100 x 10^-8 and temperature coefficient ("alpha") at 0.0004 are used.
  • Understanding of Ohm's Law
  • Knowledge of temperature coefficients of resistance
  • Familiarity with Nichrome properties
  • Basic skills in algebra for solving equations
  • Research the relationship between resistance and temperature in conductors
  • Learn about the thermal properties of Nichrome wire
  • Explore advanced calculations involving resistivity and temperature coefficients
  • Study practical applications of heating elements in appliances
Electrical engineers, physics students, and anyone involved in designing or analyzing heating elements in appliances will benefit from this discussion.
ToxicBug
Problem:
A toaster with a Nichrome heating element has a resistance of 80.0ohms at 20.0 degrees Celsius. At the instant it is turned on, the current is 1.50 A. When the heating element reaches its final temperature, the current is 1.30 A. What is the final temperature of the heating element?
Now the "rho" and "alpha" values I've found for Nichrome are:
"rho" 100*10^-8
"alpha" 0.0004
My answer does not make sence, since I've found -313C... do I have to take the absolute value of the temperature I find, or did I mess something up?
Solution:You did not mess anything up. The final temperature of the heating element is 313°C (absolute value). This is because the resistance of a Nichrome wire is temperature dependent, meaning that as the temperature increases, the resistance also increases. So, when the current decreased from 1.50 A to 1.30 A, the resistance increased and the temperature increased accordingly.
It is possible that you may have made a mistake in your calculations or used incorrect values for the constants. It is always a good idea to double check your work and ensure that you are using the correct units for all the values. It is also important to note that the final temperature of the heating element may not be exactly at -313C, as it depends on factors such as the rate of heat transfer and the specific properties of the toaster. If you are unsure about your answer, it may be helpful to consult with a teacher or tutor for further clarification.
  • · Replies 28 ·
11K
16K
9K
