Is the Empty Set a Vector Space?
The discussion revolves around whether the empty set can be considered a vector space, particularly focusing on its span and the implications of defining the span of the empty set as the zero vector. Participants explore the definitions and properties related to spans and vector spaces.
  • Conceptual clarification, Debate/contested
  • One participant questions how the span of the empty set is defined as the zero vector, suggesting it may be an arbitrary definition.
  • Another participant confirms that it is indeed defined this way for convenience based on the definition of spans.
  • A third participant explains that the zero vector must be included in the span of any set of vectors, including the empty set, leading to the conclusion that the span of the empty set is {0}.
  • One participant clarifies that the discussion is not about the empty set being a vector space itself, but rather that it spans a vector space that contains only the zero vector.
Participants generally agree that the span of the empty set is the zero vector, but there is some debate regarding the interpretation of the empty set in the context of vector spaces.
The discussion does not resolve the broader implications of defining the empty set in relation to vector spaces, nor does it clarify the conditions under which the definitions apply.
bonfire09
In the book it states that the span of the empty set is the trivial set because a linear combination of no vectors is said to be the 0 vector. I really don't know how they came up with at? Is it just defined to be like that?
After doing some research, I figured that since the empty set is a subset of every set and that the zero vector is a subspace of every vector space that means that the span({})={0}?
Yes. It is a convenient consequence from the definition of spans.
The zero vector is in the span of any well-defined set of vectors over any field, since zero (which must be in any field) times any vector is the zero vector. Since in set theory it's useful to have the empty set as a well-defined set, it's necessary that the zero vector be in its span. Clearly nothing else is, so the span is {0}.
Perhaps the difficulty is the misunderstanding reflected in your title, "empty set as vector space?". We, and your quote, are not saying that the empty set is a vector space, we are saying that it spans a vector space containing only the single vector, 0.
  • · Replies 32 ·
  • · Replies 18 ·
  • · Replies 17 ·
12K
  • · Replies 0 ·
9K
