| New Reply |
Most probable speed of Aluminium |
Share Thread | Thread Tools |
| Jan20-13, 01:45 AM | #1 |
Figure 1 shows a type of apparatus for investigating the speed distribution f (v) of molecules in a gas. Molecules emerge into a vacuum chamber from an oven held at a constant temperature T, and are collimated by slits into a parallel beam directed towards a pair of discs rotating at a common angular speed ω, which may be varied. The discs are a fixed distance L apart (L = 262 mm) and contain narrow notches, with the second notch offset from the first by a fixed angle θ = 30° as shown. If a molecule is moving at the correct speed v, it will pass through the notches in both discs to be collected at the detector, which records the rate of arrival of molecules The oven contains aluminium at 9.00 × 102 °C, which emerges as a monatomic beam. Calculate the speed vmp and the corresponding rotation speed ω at which the largest rate of arrival for aluminium atoms is observed. (The molar mass of aluminium is 0.0270 kg mol−1.) 2. Relevant equations Vmp= Square root 2RT/M 3. The attempt at a solution v = ωL/θ Can any one please help me to taht I am doing the right thing? |
| Jan20-13, 05:57 AM | #2 |
Recognitions:
| Jan20-13, 06:10 AM | #3 |
I am working on it. Do I have to change degree to rad?
| Jan20-13, 06:18 AM | #4 |
Recognitions:
| Jan20-13, 06:34 AM | #5 |
Thank you!
| Jan21-13, 05:30 AM | #6 |
Can any one explain why we always use radian instead of degree?
| Jan21-13, 07:59 AM | #7 |
In calculus, at least, the derivative (rate of change) of sin(x) is just cos(x) as long as x is in radians. If you were to use degrees it would be (180/pi) cos(x). The first formula is simpler.
Another way of looking at it (and the reason for that previous formula) is that "360 degrees in a circle" is purely arbitrary. But a circle has a "natural length", it radius. And the radian measures how many radii would fit around the part of the circle's circumference subtended by the angle, so is a "natural" measure. |
| Jan21-13, 08:08 AM | #8 |
Recognitions:
Degrees are an arbitrary unit chosen because 360 happens to be a number with lots of convenient factors. In antiquity this was very handy when all calculations were performed by hand. |
| Jan21-13, 04:13 PM | #9 |
Could u plz share your working.
| New Reply |
| Thread Tools | |
Similar Threads for: Most probable speed of Aluminium
| Relationship between most probable speed & rotation speed (gas) | Introductory Physics Homework | 3 | ||
| Most probable speed of aluminium atoms | Introductory Physics Homework | 2 | ||
| Calculating most probable speed | Advanced Physics Homework | 7 | ||
| [SOLVED] Calculating a particles most probable speed | Introductory Physics Homework | 3 | ||
| Most probable molecular speed? | Advanced Physics Homework | 9 | ||
