New Reply
Weight of a fluid when I put my finger in it
Share Thread Thread Tools
Jan21-13, 04:09 PM   #1
Hi. I was asking myself the following question.
What happens if I have a fluid at rest inside a container, and I introduce my finger in it without applying any force to the walls? Will the weight of the whole system change?
My intuition says no (If I don't exert a force on the fluid this doesn't exert a force on the ground, and thus the normal force of the ground (weight) is still the same), but I don't really know how to explain it (I'm not really satisfied with the previous explanation). Can someone give me a hand?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan21-13, 04:32 PM   #2
You are exerting a downward pressure on the fluid. You have to push your finger in against the pressure of the fluid. That upward force is buoyancy. By Newton's third law the fluid experiences an equal and opposite downward force. The upward force on you and the downward force on the fluid are both computed by the density of the fluid times the displaced volume times the acceleration of gravity.
A different way of arriving at the same conclusion is to notice that the height of the fluid will rise. That means more pressure on the bottom of the container. If it is resting on a scale, the scale will display a higher reading as a result.
Jan21-13, 04:33 PM   #3
Mentor
Quote by Pepealej View Post
I assume you mean something like a beaker of water sitting on a scale and you put your finger in it without touching the walls? And your question is: does the scale reading change?
What makes you think you don't exert a force on the fluid? Also, what happens to the level of the fluid in the container?
Jan21-13, 04:37 PM   #4
Recognitions:
Gold Membership Gold Member
Pepealej,
You've asked an interesting question. Why do you not arrange an experiment and try exactly what you describe? Find a good quality (probably digital readout) scale. Put a beaker full of liquid on it and record the weight. Then introduce your finger. Note any difference. You've already formed a hypothesis. This is clearly described as the "Scientific Method", which you could look up.
Let us know the results!
Cheers,
Bobbywhy
Jan21-13, 04:37 PM   #5
Is it possible to put your finger in the fluid without applying any force to the walls.
You intuition will probably be wrong.Why not place a container on a scale with fluid in it and do what's required.
Jan21-13, 04:44 PM   #6
Thanks for all the replies. I've understood what all of you meant about the buoyancy force.
The weight of the container will increase as the total weight of water displaced by my finger, because the water is exerting a buoyant force on my finger and, by Newton's 2nd law, my finger exerts the same but opposite force on the liquid.
Thanks so much :)
Jan21-13, 04:51 PM   #7
Mentor
Good! (But you mean Newton's 3rd law.)
But do actually try it.
Jan21-13, 05:03 PM   #8
Quote by Doc Al View Post
Try it with a small beaker, a large beaker and a very full Erlenmeyer flask (or any container that has a broad flat bottom and a narrow neck).
Obviously the change in the height of the fluid in the various cases will be different. An analysis that looks at the resulting change in pressure on the bottom of the container will predict one thing. An analysis based on buoyancy will predict another.
What does experiment say?
Can you reconcile the apparent discrepancy between the two theoretical predictions?
Jan22-13, 07:49 PM   #9
Quote by Bobbywhy View Post
Pepealej,
Cheers,
Bobbywhy
I'm interested and would love to conduct this experiment! I just don't have the equipment and resources to do it. :( Maybe next time.
New Reply
Tags
fluid, mechanics, weight
Thread Tools
Similar Threads for: Weight of a fluid when I put my finger in it
Thread Forum Replies
Buoyancy and Weight of the Fluid Displaced Introductory Physics Homework 1
Can finger stick together? Biology 5
Fluid, pressure and weight question Introductory Physics Homework 0
Finger vs. Fan Introductory Physics Homework 2
Cutting your finger General Physics 6
