| New Reply |
Fluid mechanics: Flow and velocity of a fluid |
Share Thread |
| Jan21-13, 04:52 PM | #1 |
I've rencently been thinking about several systems related to fluid mechanics, and I've asked myself the following question:
If I have a cylidrical tank with a small hole in the bottom (the surface area of the hole is small in comparison with that from the tank) and I'm filling the tank with water at a constant flow, how can I determine the speed of the water both coming from the whole and rising up the tank: (A) with respect to the height of the water in the tank, (B) with respect to time. (This is not homework, although it sounds like so) I know how to determine the maximum height of a system like this one with a specific flow Q. If the surface area of the cylinder is A and that from the hole is S, we have: [tex]Av_A=Q=Sv_S[/tex] thus [tex]v_S=\frac{Q}{S}[/tex] And, using Bernouilli's equation: [tex]P_{at}+\rho g h=p_{at}+ \frac{1}{2}\rho v_S^2[/tex] [tex]h=\frac{v_S^2}{2g}[/tex] But that is considering the end point. Where the system is 'at rest' (there's the same amount of fluid in the tank and we can treat it like a pipe), but I don't know how to study the intermediate steps. Thanks for your help :) |
| Jan21-13, 06:48 PM | #2 |
You need to consider the viscosity of the fluid and the diameter and length of the hole, then solve for the back pressure equaling the static fluid pressure at the depth of the hole.
| Jan21-13, 11:52 PM | #3 |
You need to do a transient mass balance on the volume of liquid in the tank. If V is the volume of liquid in the tank, then V = hA. The time rate of change of V is equal to the flow rate in minus the flow rate out. Write a differential equation for this.
| Jan22-13, 09:21 AM | #4 |
By the way, the calculaitons I did are correct?
| Jan22-13, 09:46 AM | #5 |
Not quite right. You need to take a look at the Navier-Stokes equations for incompressible fluids. Or you can just look up the equations for flow thru an orifice.
| Jan22-13, 10:17 AM | #6 |
If the pressure head in the tank is much higher than the frictional pressure drop for flow through the oriface, the latter can be neglected (which is what, at the OPs level of experience, the problem statement intended). The mass balance on the tank is
[tex]A\frac{dh}{dt}=Q-Sv_s[/tex] with [itex]v_s=\sqrt{2gh}[/itex] So, [tex]A\frac{dh}{dt}=Q-S\sqrt{2gh}[/tex] Just solve this differential equation subject to some initial height h0. |
| Jan28-13, 03:48 AM | #7 |
When does the continuity equation apply? |
| Jan28-13, 06:15 AM | #8 |
This actually is the continuity equation (mass balance equation) on the macroscopic scale (input minus output = accumulation). On the microscopic scale, if the fluid is incompressible, the divergence of the velocity vector is still equal to zero everywhere in this situation. You know this because, at any instant of time, the downward velocity of the fluid in the tank is not varying with depth.
Chet |
| New Reply |
| Tags |
| flow, fluid, mechanics, tank, water |
Similar discussions for: Fluid mechanics: Flow and velocity of a fluid
| Fluid Mechanics HW How pressure in a tank affects exit velocity of a fluid | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Fluid mechanics, open water channel velocity - bernoulli & conservation of flow | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Fluid Mechanics - Turbulent flow velocity profile | Engineering, Comp Sci, & Technology Homework | 5 | ||
| Fluid mechanics: Pressure and Velocity of gas flow in a heated pipe | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Fluid Mechanics: Inviscid flow v.s. Laminar flow | Engineering, Comp Sci, & Technology Homework | 1 | ||
