Minimizing I-Beam Deflection for Cantilevered Loads
  • Thread starter Thread starter hedons
    Deflection
The discussion revolves around minimizing deflection in a cantilevered I-beam under a concentrated load. Participants explore various modifications to the beam's cross-section while adhering to specific constraints on dimensions and material properties.
  • One participant outlines four options for modifying the I-beam's cross-section: increasing the upper flange width, lower flange width, upper flange thickness, or lower flange thickness, and seeks to understand which would most effectively minimize deflection.
  • Another participant questions whether the load is distributed or concentrated and whether the cross-section must remain constant, emphasizing the importance of maximizing the moment of inertia.
  • A participant suggests that increasing flange thickness may be beneficial due to its impact on the moment of inertia and the center of gravity.
  • Concerns are raised about the potential for increased stress if the beam becomes asymmetrical, particularly if material is added in a way that alters the neutral axis.
  • It is noted that the top of the beam is in tension while the bottom is in compression, suggesting that a thicker or wider flange at the top may be advantageous.
  • Another participant proposes that creating a changing profile from the tip of the beam could be optimal, given the constraints provided.
Participants express various viewpoints on the best approach to modifying the I-beam's cross-section, with no clear consensus on which modification would be most effective in minimizing deflection. The discussion remains unresolved regarding the optimal strategy.
Participants mention the importance of calculating the moment of inertia for different configurations, but there are no settled definitions or formulas provided, and assumptions about material properties and load conditions are not fully explored.
hedons
Hi,
I am working on a project where I have an I-Beam supporting a cantilevered load.
..........W
IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
For ease of fabrication, I need change the cross section of this I-beam.
Due to other limitations:
1. I cannot increase the web thickness.
2. I cannot increase the I-beam height.
My options are to :
1. Increase the upper flange width.
2. Increase the lower flange width.
3. Increase the upper flange thickness.
4. Increase the lower flange thickness.
In order of their benefit, which of those four parameters, if increased in equal amounts, will help to minimize the beam deflection while under load?
I was not sure if there are general rules of thumb to apply here or If I actually need to determine the Moment of Inertia for each proposed cross section to carry out the beam deflection calculations.
Thanks!
I am reading your diagram as a distributed load. Is that the case or is it a concentrated load at the end?
Does the cross section of the beam have to be constant for the entire length of the beam?
What do you consider a benefit? A smaller deflection? Since you are limited in the real beneficial changes you can make (short of material change which you did not mention) I would simply do my best to maximize your moment of inertia. If you set up a spread sheet, you can easily calculate the values with various geometry.
Hi Fred,
It is a concentrated load at the end.
The beam doesn't have to be of a constant cross section, however there is nothing to be gained (except extra fabrication costs) by tapering it as the arm increases.
I'll set up the spreadsheet and start plugging in numbers.
Thanks again.
Yes, off the top of my head, the moment of interia of a rectangle is (bh³)/12 + Ad² where d is distance from CG? Either way it's close I think, haha. based on this, I would think your best bet is to increase the flange thickness. Not only is moment of interia a function of h³, but it will also increase the CG of that rectangle slightly which will increase the distance from it's CG to the CG of the beam...if I'm not mistaken.
"My options are to :
In order of their benefit, which of those four parameters, if increased in equal amounts, will help to minimize the beam deflection while under load?"
Assuming you're looking for lower stess or reduced deflection, adding material as far away from the centerline is the most desirable. One thing to beware of: If you make the beam asymmetrical, you can raise stress. For instance, if you made a t beam by taking the bottom flange off and adding that material to the top flange, your moment of inertial would probably decrease. The distance from the neutral axis to the edge where the bottom flange was will increase and that will result in higher stress.
You mentioned tapering the beam. For the load case stated you can reduce weight significantly. Basically you can have a small thickness at the end (enough to sustain the shear load) and the rest of the beam can be tapered so that it is at the maximum allowable stress for the material.
Also consider that the top of the beam is in tension while the bottom of the beam is in compression. So it would be ideal to have a thicker or wider flange at the top as opposed to the bottom.
Yeah, if you're free to work with the profile even with the dofs you've given creating a changing profile from the tip would be optimal.
