Pressure At Surface And Scale Height
The discussion focuses on calculating the scale height (λ) of a planet's atmosphere using pressure values at different altitudes. The user provides atmospheric pressure measurements at 6 km (0.5 P0) and 8 km (0.4 P0) and attempts to derive λ using the equation P(z) = P(0)e^(-z/λ). The user correctly sets up the equation but encounters confusion when manipulating logarithmic terms. The key takeaway is that the logarithmic transformation must be applied correctly to isolate λ without cancellation errors.
  • Understanding of atmospheric pressure concepts
  • Familiarity with the exponential decay model
  • Knowledge of logarithmic functions and their properties
  • Basic algebraic manipulation skills
  • Study the derivation of the scale height formula in atmospheric science
  • Learn about the applications of the barometric formula in different planetary atmospheres
  • Explore logarithmic identities and their applications in solving equations
  • Investigate common mistakes in algebraic manipulations involving exponentials and logarithms
Students and professionals in atmospheric science, physics, or engineering who are interested in understanding atmospheric pressure calculations and scale height derivations.
bobbles22
Please can someone tell me if my thinking here is right...
I've got a planet with an atmospheric pressure at 6km of 0.5 P0 and at 8km of 0.4 P0 (P0 = pressure at the surface).
I want to work out the scale height of the atmosphere.
Given scale height = λ
and for height above surface = z
P(z)=P(0)e(-z/λ)
I could rearrange to show the pressure at the surface as:
P(0)=P(z)/e(-z/λ)
I could then use the relative pressure, assume P(0)=1 (as it will cancel out shortly) and height from each of the know quantities and set them equal to each other like this:
0.4/e(-8000/λ) = 0.5/e(-6000/λ)
A little mutliplication...
0.4 e(-6000/λ) = 0.5 e(-8000/λ)
Take the Log of both sides...
(-6000/λ) log 0.4 = (-8000/λ) log 0.5
But know I'm left with the λ cancelling out if I multiply both sides by λ. I'm sure I've gone wrong here somewhere. Probably something very simple. Can anyone advise? Have I made a simple mistake in my working or have I gone completely off the reservation and need to start again? I just need to end up with λ = xxx metres.
Thank you.
hi bobbles22! :smile:
nooo :wink:
(-6000/λ) + log 0.4 = (-8000/λ) + log 0.5 :smile:
  • · Replies 45 ·
