Calculating Force of Friction: A Homework Help Guide
The discussion revolves around calculating the force of friction acting on a wooden crate being pulled across a concrete floor. The problem involves a force applied at an angle and considers the crate's constant velocity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the applied force, the angle, and the force of friction. There are attempts to clarify the notation used for forces and to understand the role of the crate's weight in the calculations.
Participants are exploring the implications of constant velocity on the forces involved and questioning how the weight of the crate factors into the equation for force of friction. Some guidance has been offered regarding the relationship between the horizontal component of the applied force and friction.
There is a mention of the need to find the coefficient of friction, although the primary focus remains on determining the force of friction itself. The discussion highlights the assumption that the weight of the box does not directly influence the final equation for friction in this context.
tyler hartman
Force of friction help!
A force of 755N is exerted on a rope to pull a 45.0N wooden crate across a concrete floor. If the rope makes an angle of 35.0° with the floor and the crate is moving at a constant velocity what is the amount of the force of friction?
F=ma
So far I have x: F=Fcosθ-Ff=ma I am not sure if that's the right equation given mg, Fa and angle
Please don't use the same label (F in this case) for two different entities. Let's call the rope tension T. So, yes, you have Fx = Tcos(θ) - Ff = ma. What do you know about a?
It equals 0 because its at a constant velocity? I think haha
Quite so.
So that means that Ff=Tcosθ?
Yes. I assume there's more to this question. Do you have to find the coefficient?
no, just the force. I am confused on how the weight of the box is not used whatsoever in the end equation?
The only horizontal forces are friction and the horizontal component of the applied force. Therefore, the weight of the box is not involved.
It is possible to find the coefficient of friction from the given information. To so this, the weight of the box would be involved.
Due to the weight of the box we get that the force of friction is a certain magnitude. From the fact that the box is not accelerating we then know that horizontal component of the pull must be equal to the force of friction and because we can calculate this from the information we have the force of friction. This is exactly how the force of friction is measured experimentally - pull the block along at a constant speed with a spring scale and take its reading. The force of friction is then eual to the reading on the spring scale if it was held horizontally during the pull.
