Kinematics and acceleration problem
The problem involves kinematics, specifically the motion of a particle with a time-varying acceleration given by a = (4t² - 2) m/s². The particle's initial position and its position at t = 2 s are provided, and the goal is to determine its position at t = 4.3 s.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to integrate the acceleration to find velocity and position, questioning the validity of using constant acceleration equations. There are attempts to derive the position function and determine constants of integration based on given conditions.
Some participants have provided guidance on integrating the acceleration equation and finding the constants of integration. There is an ongoing exploration of the implications of the initial conditions on the constants, with some participants expressing uncertainty about their calculations and results.
Participants note the importance of correctly applying initial conditions to determine constants in the equations of motion. There is mention of potential rounding errors affecting the final results.
aaronfue
A particle moves along a straight line such that its acceleration is a = (4t2-2) [itex]\frac{m}{s^2}[/itex], where t is in seconds. When t = 0, the particle is located 1 m to the left of the origin, and when t = 2 s, it is 20 m to the left of the origin. Determine the position of the particle when t = 4.3s.
2. Homework Equations & The attempt at a solution.
I am just stuck on this. I know I should already know how to do this but right now my mind is blank!
I know that I can get the velocity equation by integrating, but when I try to use t=2 s, and then using the equation x=xo+vot+[itex]\frac{1}{2}[/itex]at2, I am not even close to the x=20.
The kinematics equation you mention is good only for constant acceleration, but the acceleration in the problem varies with time, so you have to go back to basics. Start with the definition of acceleration: [itex]a = dv/dt[/itex].
That equation is only valid for constant acceleration.
What do you get when you integrate the acceleration equation?
After I integrate the acceleration, I get:
v(t)= ([itex]\frac{4}{3}[/itex]t3 - 2t) [itex]\frac{m}{s}[/itex]
Don't forget the constant of integration.
Then get the equation for distance as a function of time.
Then the next step is to find the displacement.
s(t) = [itex]\frac{t^4}{3}[/itex] - t2 + c1t + c2
c1 is the constant after integrating for v(t) & c2 is the constant for s(t).
Do I have to set the constants equal to the given positions and t=0 and t=2?
No. You plug in the value for [itex]t[/itex], and then solve for the constants.
Ok. I plugged in the t=0, s=1 and got c2 = 1 (I think this would be -1 since the location is to the left of the origin?)
So I then plugged t=2, s= -20 and my c1 = -9.84
Finally I plugged my c1 and c2 into my s(t) equation:
s(t) = [itex]\frac{1}{3}[/itex]t4 - t2 - 9.84t -1
And after using t=4.3, I got s = 52.16 m
Unfortunately, this is not correct. The correct answer was 50.8 m. I'm not sure where I messed up, but I'm thinking it was my rounding.
Found my mistake! I was subtracting my numbers from +20 and not using -20 when calculating my c1!
I got:
s = 50.75 = 50.8 m!
Dang!
  • · Replies 22 ·
