What is the pH at halfway to the equivalence point?
The pH at halfway to the equivalence point in the titration of 25.00 mL of 0.20 mol/L formic acid (HCO2H) with 0.26 mol/L sodium hydroxide (NaOH) can be calculated using the Henderson-Hasselbalch equation. At this point, 0.0025 moles of formic acid remain, and the concentration of its conjugate base, formate (HCO2-), is equal to that of the acid. The pH is determined to be equal to the pKa of formic acid, which is approximately 3.75.
  • Understanding of titration concepts and equivalence points
  • Familiarity with the Henderson-Hasselbalch equation
  • Knowledge of acid-base chemistry, specifically weak acids and their conjugate bases
  • Basic skills in stoichiometry for calculating moles and concentrations
  • Study the Henderson-Hasselbalch equation in detail
  • Learn about the properties and applications of weak acids and their conjugate bases
  • Explore titration curves and how to interpret them
  • Investigate the pKa values of common weak acids
Chemistry students, educators, and laboratory technicians involved in acid-base titrations and pH calculations.
sangdeep
If 25.00 mL of 0.20 mol/L HCO2H(aq) is titrated with 0.26 mol/L NaOH(aq) determine the pH at halfway to the equivalence point. So far I have:
Moles of HCO2H = 0.005 mol; at half way = 0.0025 I don't know the next step.
Don't let the superfluous information in the question confuse you.
