Find Cliff Height | Physics Homework
  • Thread starter Thread starter Toranc3
    Height
The problem involves determining the height of a cliff based on the time it takes for a rock to fall and the sound of it hitting the ground to travel back up. It is set in a physics context, focusing on kinematics and the behavior of sound. The original poster presents two parts to the question, including a consideration of the effects of ignoring sound travel time.
  • Participants discuss the relationship between the time it takes for the rock to fall and the time for the sound to travel back up. There are attempts to set up equations based on kinematic principles, with some questioning the accuracy of the equations used. Others explore the implications of ignoring the time for sound to travel in their calculations.
The discussion is ongoing, with some participants providing guidance on the setup of equations and the importance of solving symbolically. There is a recognition of the need to clarify assumptions about the behavior of sound and gravity, particularly regarding how sound is treated in the context of the problem.
There is a noted confusion regarding the correct application of kinematic equations and the treatment of sound in the problem. Some participants express uncertainty about specific aspects of part b of the question, indicating a need for further clarification.
Toranc3
Suppose you are climbing in the high sierra when you suddenly find yourself at the edge of a fog shrouded cliff. To find the height of this cliff, you drop a rock from the top and 10 s later, hear the sound of it hitting the ground at the foot of the cliff.
a) Ignoring air resistance, how high is the cliff if the speed of sound is 330 m/s?
b) Suppose you had ignored the time it takes the sound to reach you. In that case, would you have overestimated or underestimated the height of the cliff? Explan your reasoning.
y=yo+vo*t+1/2*a*t^(2)
-b +or- [Sqrt(b^(2)-4ac)]/2a
t1=time for the rock to fall to the ground.
t2=time for the sounds to go from bottom to top of cliff
t1+t2=10seconds
For rock falling down:
0=H-4.905m/s^(2)*t1^(2)
For sound coming up from the bottom:
H=330m/s*t2 - 4.905m/s^(2)*t2^(2)
substitute t2 with (10seconds-t1) and then equate the equations from sound and rock.
4.90m/s^(2)*t1^(2)=330m/s(10s-t1)-4.905m/s^(2)(10s-t1)^(2)
I end up with 9.81m/s^(2)*t1^(2) + 231.9m/s*t1-2809.5m
I use the quadratic formula to get this
t1=8.8224 seconds
I end up with H=381.7850m.
I do not get part b though.
y=yo+vo*t+1/*a*t^(2)
-b+- Sqrt(B^(2)-4ac)/2a
Be careful with how you write the equations. Neither of these is correct.
t1=t2=10seconds
This is also not correct.
When working problems, it is always best to solve the problem symbolically, and only plug in numbers at the very end. One problem with plugging in numbers in the beginning is that you force your readers to figure out what the numbers are and where they come from.
Why the second term on the right?
What don't you get about it?
Sound is not subject to gravity!
So for sound 1/2*a*t^(2) should go to zero right? Got it thanks guys!
