Forced vibrations w/ damping problem
  • Context: Undergrad
  • Thread starter Thread starter huk
    Damping Vibrations
The discussion focuses on a forced vibrations problem involving a mass-spring-damper system. The mass, initially weighing 8 lb, is subjected to an external force of 4cos(2t) lb and a damping constant of 0.25 lb-sec/ft. The steady-state response is determined as U(t) = (8/901)(30cos(2t)+sin(2t)) ft. The challenge lies in finding the mass m that maximizes the amplitude of the steady-state response, which involves calculus to derive the amplitude function A(m) and setting its derivative dA(m)/dm to zero for maximization.
  • Understanding of forced vibrations in mechanical systems
  • Knowledge of spring constants and damping coefficients
  • Proficiency in calculus, particularly differentiation
  • Familiarity with harmonic functions and their properties
  • Study the principles of forced vibrations in mechanical systems
  • Learn about the effects of damping on system response
  • Explore optimization techniques in calculus
  • Investigate the relationship between mass and amplitude in oscillatory systems
Mechanical engineers, physics students, and anyone involved in the analysis of dynamic systems and vibrations will benefit from this discussion.
huk
A spring is stretched 6 inches by a mass that weighs 8 lb. The mass is attached to a dashpot mechanism that has a damping constant of 0.25 lb-sec/ft and is acted on by an external force of 4cos(2t) lb.
a) Determine the steady-state response of this system
b) If the given mass is replaced by a mass m, determine the value of m for which the amplitude of the steady-state response is maximum.
I got part a but didnt get part b... I am not sure where to start... can anyone tell me how to start it? or any tips?
ps the answer to a is U(t) = (8/901)(30cos(2t)+sin(2t)) ft
thanks
Write the expression for U(t) in terms of m (do not substitute m=8 lb).
Find the amplitude A(m), to be half the difference between the minimal and maximal values of U(t). The minima and maxima can be found from dU(t)/dt = 0.
Maximize the amplitude by setting dA(m)/dm = 0.
I actually got it already. Sorry about it but thanks anyways. it was such a simple calculus problem....
  • · Replies 19 ·
  • · Replies 131 ·
9K
