What are the Final Velocities After a Proton Collides with a Carbon Atom?
The discussion revolves around a problem in classical mechanics involving a head-on elastic collision between a proton and a carbon atom. The proton is initially moving at a high speed, and participants are tasked with determining the final velocities of both particles post-collision, given the mass relationship between them.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the conservation of kinetic energy and momentum as fundamental principles to solve the problem. There are attempts to manipulate equations derived from these principles, but some participants express confusion over the complexity of the resulting equations.
Several participants have shared their equations and attempted to solve for the final velocities. There is an ongoing exploration of the validity of the proposed solutions, with some participants questioning the accuracy of their calculations and the assumptions made regarding the initial conditions.
There is mention of the initial velocity of the carbon atom being zero, which is a critical assumption in the problem setup. Additionally, some participants reference the potential need to consider relativistic effects, although others suggest sticking to non-relativistic physics for simplicity.
Xerxes1986
A proton is traveling to the right at 2.0E7 m/s. It has a head-on perfectly elastic collision with a carbon atom. The mass of the carbon atom is 12 times the mass of the proton. What are the speeds of each after the collision?
i was trying to tinker with the fact that the KE before and after the collision will be equal and so will be the momentum. but when i solve the equation i get 5773502 m/s but it doesn't work...i don't know how to even start this problem...
There's a trick here.v/c~1/15,sot the errors in chosing Newton's dynamics to Einstein's one is less than 1%.If you're not interested in accuracy,you might chose the simpler framework offered by nonrelativistic physics.
What's the intial velocity of the C atom...?
Daniel.
Daniel.
ok that just flew right over my head...einstein? umm how bout a simple solution? lol this is supposed to be simple...
the C atom isn't moving when the proton hits it
Perfect.Then apply the laws of conservation of KE and momentum...Write the latter in vector form and choose the axis of movement as the axis of projection with the positive sense being the sense of the initial proton's velocity.
Daniel.
Daniel.
i tried but i getg like some really REALLY weird equation that doesn't work...what equations should i try to manipulate around
dextercioby said:
Post the 2 equations.
Daniel.
lol ill try
.5*m_p*2E7^2=.5*m_p*v_fp^2 + .5*12m_p*v_fc^2
and
m_p*2E7=m_p*v_fp + 12m_p*v_fc
and then substitute right? well i got a equation with v_fc^4 in it and it has 4 roots...none of which are the right anser
The system:
[tex]12(v_{C}^{fin})^{2}+(v_{p}^{fin})^{2}=(v_{p}^{init})^{2}[/tex]
[tex]12v_{C}^{fin}+v_{p}^{fin}=v_{p}^{init}[/tex]
has the physically acceptable sollutions
[tex]v_{C}^{fin}\approx 3\cdot 10^6 \ m \ s^{-1}[/tex]
[tex]v_{p}^{fin}\approx -1.7\cdot 10^{7} \ m \ s^{-1}[/tex]
Can u convince yourself of the validity of these answers?
Daniel.
dextercioby said:
The system:
Daniel.
i don't know howyou got them but the v_c one isn't right because when i enter it it says "your close but your answer is off...rounding error or something"
Rounding error...?That's bull****.The next figure after 3 is 0...Anyway,to get the full #,solve the system.It's basically a quadratic that u must solve,the only problem being that it has quite large coefficients.
Daniel.
Xerxes1986 said:
lol ill try
and
So far, so good.
You must be making an error here. If you eliminate v_fp, then you'll get a quadratic equation with v_fc. Do it over.
  • · Replies 16 ·
