Earnshaw's Theorem and electrostatics
Earnshaw's Theorem establishes that stable equilibrium in electrostatics is impossible. The theorem is proven by analyzing a charge Q at point P and applying Gauss's Law, which leads to a contradiction when assuming stable equilibrium. The discussion also explores a scenario with point charges at the corners of a square, examining the stability of a test charge q placed at the center. The divergence of the electric field E being zero does not imply stable equilibrium, as it can indicate metastable states.
  • Understanding of Earnshaw's Theorem
  • Familiarity with Gauss's Law
  • Knowledge of electric fields and charge interactions
  • Concept of stable versus metastable equilibrium
  • Study the implications of Earnshaw's Theorem in electrostatics
  • Learn about Gauss's Law applications in different geometries
  • Investigate the concept of metastable states in physics
  • Explore electric field calculations for multiple point charges
Students of physics, particularly those studying electrostatics, educators teaching concepts of electric fields, and researchers exploring stability in charged systems.
arishorts
14: a: It is impossible to have a stable equilibrium in electrostatics. This idea is known as Earnshaw’s Theorem. Let’s prove this fact. Assume that at a particular point P that a charge Q is in a stable equilibrium. Think about the direction of E⃗ necessary for the equilibrium. Now use Gauss’ Law with a spherical gaussian surface centered on P. Show that this leads to a contradiction.
b: Imagine a square in the xy plane with a point charge Q fixed at each corner. Now put a test charge q in the exact center of the square. What direction(s) can we move q in for which the equilibrium is stable? For which it is not stable? Explain.
Gauss's equation: (E*A)/(Qenclosed*(Permittivity of free space))
I've figured out that the direction of E has to be inward, but i don't understand why. With some research I've found the proof where the divergence comes out to zero, but wouldn't that mean it achieves stable equilibrium? Seems a bit contradictory. Also, if you use a spherical versus a circular surface, you get a difference in answer by a factor of 1/3... That's the best i can do. Please help.
No, that could be metastable, like a ball on a surface that is fully horizontal.
I like your analogy, a lot actually. But how can i prove that using Gauss' theorem leads to a contradiction?
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 26 ·
