Electric shock via ground that becomes live.
The discussion centers around the safety measures recommended for individuals operating cranes in the vicinity of overhead electrical wires, particularly the advice to jump out of the cab and use small steps or hopping to avoid electric shock. Participants explore the reasoning behind these recommendations, the concept of ground potential rise, and personal experiences related to electric shocks from the ground.
  • Personal experience
  • Some participants question the effectiveness of taking small steps or hopping on one leg to avoid electric shock, seeking clarification on the potential contour of the ground.
  • One participant suggests that keeping one leg in contact with the ground reduces the risk of becoming a conductor, implying that two legs touching the ground could increase the risk of shock.
  • A personal account is shared regarding experiencing a shock from the ground due to lightning while cycling, indicating that such shocks can be felt distinctly in the legs.
  • Links to videos about step potential safety and ground potential rise (EPR/GPR) are shared, indicating interest in visual resources on the topic.
  • Another participant discusses the design of ground mats in substations to minimize voltage drop across a person's stride, suggesting that such safety measures may not be present in all locations, like where cranes operate.
  • There is a humorous exchange about the reasons flamingoes stand on one leg, with some attributing it to lightning safety while others suggest it relates to circulation and thermoregulation.
  • A participant with experience in the electric utility industry warns about the risks of walking in wet ground near power lines, explaining the potential for ground current to create a dangerous situation during faults.
Participants express a mix of agreement and differing views on the safety measures discussed. While some support the idea of hopping or taking small steps, others raise questions about the underlying physics and safety practices, indicating that the discussion remains unresolved.
There are references to specific safety practices in the electric utility industry and personal experiences with electric shocks, but the discussion does not resolve the technical aspects of ground potential rise or the effectiveness of the recommended safety measures.
rollingstein
Was reading a crane-operations manual and it had a Section on what to do if your boom accidentally contacted overhead electrical wires. It advised not trying to step out of the cab (of course); but in case of imminent danger advised jumping out (makes sense).
The interesting part came after this: It said to take tiny steps or hop on one leg to get away from the live equipment. Apparently the reasoning is the ground may have become live and a bigger step would be across a potential high enough to injure.
Does this strategy make sense? What's the typical potential contour and could a potential drop across a stride be so high to shock via two legs?
I think they're afraid that if your two legs both touch the ground they will become a conductor so by having only one in contact that lessens the chance.
Many years ago I was the victim of live ground.
This was due to lightning and I was on a bicycle at the time, cycling past the aptly named Bay of Storms in Italy.
I can confirm you get a definite feeling in the legs.
dlgoff, A most interesting link, many thanks.
it's part of substation design to provide a ground mat sufficiently 'stout' that, should a fault occur, the voltage drop across the ground over the distance of a man's stride is small enough to not electrocute him.
There's no probably such ground mat under a crane out in the boondocks, so OP's surmisal seems correct..
Re studiot's bicycle - i was once swimming in a lake when lightning struck a couple miles away. Definitely felt the shock. Scared the daylights out of me.
I believe American Flamingoes stand on one leg for that reason. Florida Everglades is one of world's most active lightning zones.
oops - i see two posts appeared while i was typing...
nice find, dig...
old jim
Ha!That's a new one. I thought it was to do with their circulation / thermoregulation.
Same goes for the Original Karate Kid in his famous finale standing on one leg ready for the shock of winning.
I agree with the others. I work for an electric utility and we have warnings about walking in wet ground around power lines. We have to wear dielectric boots if working in those conditions.
If there is a phase to ground fault on a power line (like a crane contacting a line) and you are standing in the ground return path to the substation, there is a risk of a ground potential rise between your legs. Whatever fault current is flowing through the crane travels through the ground back to the neutral of the substation transformer, so there can be considerable ground current flowing (hundreds or thousands of amps depending on the line).
  • · Replies 31 ·
9K
  • · Replies 71 ·
17K
9K
11K
