Will a push out window or half slide window cool down a room faster?
The discussion centers on the comparative cooling efficiency of push out windows versus half slide windows. A push out window offers a larger open area but can block wind depending on its angle, while a slide window provides direct airflow over a broader angle, particularly in moderate to high wind conditions. The effectiveness of each window type in cooling a room is contingent upon wind direction and the angle of the window. In still air, both window types perform similarly, but their performance varies significantly with wind conditions.
  • Understanding of window types: push out and half slide windows
  • Basic principles of aerodynamics and airflow
  • Knowledge of thermal dynamics related to indoor cooling
  • Familiarity with draught-proofing concepts
  • Research the impact of window angle on airflow dynamics
  • Explore thermal dynamics in relation to indoor air quality
  • Investigate draught-proofing techniques for different window types
  • Learn about the effects of wind direction on indoor temperature regulation
Homeowners, architects, HVAC professionals, and anyone interested in optimizing indoor cooling through window design and placement.
questionboy
If you have a push out window the whole area is open but much of the wind is blocked depending on the angle. With a slide window you often have half the open area but you can get direct wind over 180 degree angle.
Which one will cool the room down faster under which circumstance? If there is no wind will the push out window let more hot air out. If there is moderate to high wind will the slider let the wind bring down the temperature?
Science news on Phys.org
It all depends upon the direction of the wind and the angle of the hinged window. It could be better or it could be worse. Aerodynamics is a complicated business.
I guess that with no wind, a hinged window wouldn't be very different from a slide opener.
But how would you compare the two , if you're comparing their performance when only slightly open - what numerical degree of 'openness' would you assign to each one? What angle would you have the hinged window - the optimum, each time? The only time you could do a fair comparison would be when both are shut and you could then compare the draught-proofing properties (glazing area and spec being equal).
  • · Replies 32 ·
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 69 ·
18K
