New Reply
Heat Transfer - Massflow in a pipe vs pipe at constant T
Share Thread
Jan30-13, 07:54 PM   #1
Hi there,
Had a physics project in university that looked at the heat transfer of a pipe in a cement block for snow melting. When I modeled it using computational fluid dynamics, I just did a 2D model and simplified it by saying that the fluid would be moving fast enough through the pipe that the temperature change of the fluid in the circuit would be very small.
One of the physics teachers disagreed. He said that with faster mass flow rates that I'd get more heat transfer. Can you not make the assumption that if its moving fast enough to keep the temperature of the pipe constant, than faster flow rates won't increase the heat flux from the pipe to the concrete?
Thanks in advance! I'm sure this is a pretty easy question for most of you
PhysOrg.com engineering news on PhysOrg.com
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
>> Faster, more precise airstrikes within reach
>> How smart technology could change public transit
Jan31-13, 12:41 AM   #2
Faster flow would mean the temperature change of the fluid would be less.
But, as your teacher stated, heat transfer which depends on temperature differences would be higher.
New Reply
Tags
heat transfer pipe
Similar Threads for: Heat Transfer - Massflow in a pipe vs pipe at constant T
Thread Forum Replies
Heat transfer in a double pipe HE Engineering, Comp Sci, & Technology Homework 3
Heat Transfer with pex pipe Classical Physics 0
Heat transfer from pipe Materials & Chemical Engineering 10
Unsteady heat transfer inside a pipe Mechanical Engineering 0
Heat Transfer through a pipe Classical Physics 2
