How much charge is enclosed by the box?
  • Thread starter Thread starter AxM=Fam
    Box Charge
The discussion centers on calculating the enclosed charge within a box positioned in a uniform electric field defined by E = 4 N/C(i) + 5 N/C(j) + 6 N/C(k). Utilizing Gauss's Law, the participants confirm that the enclosed charge Q equals zero due to the uniformity of the electric field, which results in the electric flux canceling out across the box's surfaces. The area of the box, calculated as 6.4516 x 10^-4 m², supports this conclusion, affirming that no charge is enclosed.
  • Understanding of Gauss's Law
  • Familiarity with electric fields and flux
  • Knowledge of vector mathematics
  • Basic concepts of charge and permittivity of free space
  • Study Gauss's Law in detail, focusing on applications in electrostatics
  • Learn about electric flux and its calculation in various geometries
  • Explore the concept of uniform electric fields and their implications
  • Investigate the relationship between charge, electric field, and area
Students of physics, electrical engineers, and anyone interested in electrostatics and the application of Gauss's Law in determining enclosed charge in electric fields.
AxM=Fam
1. A box with a side of length L=2.54 cm is positioned with one of its corners at the origin of a rectangular coordinate system. There is a uniform electric field
E= 4 N/C(i) + 5 N/C(j) + 6 N/C(k).
2. I believe I should be using Gauss's Law (Epsilon=permittivity of free space)
Ie= Q/Epsilon
Ie= ExA
Area=L^2
3. I basically multiplied all sides with its proper vector x area. The area for all sides seems to be the same since all L=2.54cm=.0254m.
Area came out to be 6.4516X10^-4 m^2.
I came out with a charge=Q=0
Not quite sure if I am calculating this correctly; please help.
Since you have not shown all your steps, it's impossible to say whether you are doing it correctly. Since the field is uniform, there is certainly no enclosed charge.
Yes. That is correct to say that there is no charge since the electric field is uniform.
Area was the same all around so the electric flux canceled each other out in the i, j, z directions. Q=0.
Thanks for your help.
  • · Replies 30 ·
9K
