Finger on the top of the straw, keeping the liquid in
  • Context: High School
  • Thread starter Thread starter jaydnul
    Liquid
The discussion explains the physics behind maintaining liquid in a straw when the top is sealed with a finger. By covering the top of the straw, air pressure is eliminated, creating a vacuum that counteracts gravity. This vacuum allows the liquid to remain suspended, as the pressure difference between the atmospheric pressure at the bottom and the near-zero pressure at the top supports the liquid column. The concept is further illustrated by considering a hypothetical scenario involving a large straw submerged in Lake Erie.
  • Understanding of basic fluid dynamics
  • Knowledge of atmospheric pressure principles
  • Familiarity with vacuum concepts
  • Basic physics of pressure differentials
  • Research fluid dynamics principles related to pressure differentials
  • Explore the concept of vacuum and its applications in fluid mechanics
  • Study the effects of atmospheric pressure on liquids in various scenarios
  • Investigate real-world applications of suction and pressure in engineering
Students of physics, engineers, and anyone interested in the principles of fluid mechanics and pressure dynamics.
jaydnul
So i realize that by putting your thumb over the top of the straw, your eliminating the air pressure from the top. But why doesn't the liquid still fall out the bottom of the straw from gravity, the liquid being more dense than the air below it.
Hint: do you think it would work if the "straw" were 10 feet in diameter and of proportionate length and dunked into and then lifted out of Lake Erie via helicopter after the top had been closed off?
With your finger covering the top of the straw, if the fluid were to move downward even the slightest amount, a vacuum would form between your finger and the top of the liquid. Actually, within this tiny amount of space, the pressure would be equal to the equilibrium vapor pressure of liquid, which is very low at room temperature. So the pressure on the bottom of the liquid column would be atmospheric, and the pressure on the top of the liquid column would be essentially zero. This difference in pressure would be sufficient to support the weight of a fairly large column of liquid. In reality, no space forms, although the pressure of the fluid on the bottom of your finger will be less than atmospheric. You should feel suction on the bottom of your finger.
61K
  • · Replies 27 ·
  • · Replies 32 ·
  • · Replies 33 ·
