Solving sin3x=1/2: 6 Solutions Explained
  • Thread starter Thread starter seiferseph
The discussion revolves around solving the equation sin(3x) = 1/2, with participants exploring the number of solutions and the methods to find them. The subject area includes trigonometric equations and their periodic nature.
  • Participants discuss the periodic nature of sine and how it relates to finding multiple solutions within a specified range. Some suggest methods for deriving angles that satisfy the equation, while others explore the implications of the periodicity of trigonometric functions.
The discussion includes various attempts to solve the equation, with some participants providing insights into the periodic nature of sine and how to derive solutions. There is an ongoing exploration of different approaches, with no explicit consensus reached on a single method.
Some participants mention the importance of specifying the range for solutions, typically 0 ≤ x < 2π, and question the implications of this restriction on the solutions derived.
seiferseph
sin3x=1/2
how would i go about solving this problem? and there should be 6 solutions right, how do i get them? thanks.
The answer is x = pi/18 but I don't know how to really get it. I just thought what sin x = 1/2 (x = pi/6) and since its sin 3x, then its that /3 (pi/18).
There's six solutions because:
a) there's two angles between 0 and [tex]2 \pi[/tex] that have a sine of 1/2
b) you have 3x equals one of those two angles. In other words, for each of the angles that have a sine of 1/2, there's three angles between 0 and [tex]2 \pi[/tex] that, if multiplied by 3, would wind up at the same spot on the unit circle.
Example: [tex]\frac{13 \pi}{18} * 3 = \frac{13 \pi}{6}[/tex] which is the same spot on the unit circle as [tex]\frac{\pi}{6}[/tex]
Find each of the angles that have a sine of 1/2
Divide them by 3.
Add [tex]2 \pi[/tex] to the original angles, then divide by 3 again.
Add [tex]4 \pi[/tex] to the original angles, then divide by 3 again.
All three should lie between 0 and 2 pi.
If you added [tex]6 \pi[/tex] to the original angles and divided by 3, you would find that your answer was greater than [tex]2 \pi[/tex] (should be obvious, since [tex]6 \pi[/tex] divided by 3 is [tex]2 \pi[/tex]).
[tex]\sin 3x=\sin \ (x+2x)=\sin x \ (\cos^{2}x-\sin^{2}x)+\cos x \ (2\sin x\cos x)=...=-4\sin^{3}x+3\sin x[/tex]...
The u have to solve a cubic,assuming:
[tex]\sin x=u[/tex]
[tex]-4u^{3}+3u-\frac{1}{2}=0[/tex]...
Daniel.
[tex]\sin x=u[/tex]
Daniel.
Wow! That's an interesting solution. Are you solving the same problem he's asking? (He never did actually state what he was solving for. I just kind of assumed he was trying to solve for x.)
Edit: But, your solution does give the sine of x. A point worth noting, since most people only memorize the basic angles. If you want the sine of pi/18, you would have to multiply your angle by 3 to get an angle you did know the sine of and then solve for sine x the way dex did.
didn't have a chance to try anything yet (thanks so much for the help!), but its solving for x, and therefore all the possible angles
thanks, i think i got that one. now for cox3x=1/2, this is what i did (is it right?)
ok, so i put 3x = pi/3, 5pi/3. then divide each by 3 to get
x=pi/9, 5pi/9
add 2pi/3 and 4pi/3
for the solutions i get (Π is pi)
x=Π/9, 5Π/9, 7Π/9, 11Π/9, 13Π/9, 17Π/9
are these correct for the 6 solutions?
seiferseph said:
thanks, i think i got that one. now for cox2x=1/2, this is what i did (is it right?)
x=pi/9, 5pi/9
add 2pi/3 and 4pi/3
That is INCOMPATIBLE with the calcuations that u made...
Daniel.
you have 2x this time. using 3x will not help you.
sorry, it was actually cos3x=1/2. can anyone confirm those solutions?
[tex]\cos{3x} = \frac{1}{2}[/tex]
So...
remember that cos is positive in first and fourth quadrant...
[tex] 3x = \frac{\pi}{3}, -\frac{\pi}{3}, \frac{5\pi}{3} ...[/tex]
[tex] x = \frac{\pi}{9}, -\frac{\pi}{9}, \frac{5\pi}{9} ...[/tex]
Is there a restriction on the angles?? Because you can just keep on adding two pi onto them and it will be a valid answer.
So...
0 ≤ x < 2pi
is the restriction
(and you keep adding 2pi/3, or the period, right?)
Oopps, this is supposed to be the answers:
[tex] 3x = \frac{\pi}{3}, \frac{5\pi}{3} , \frac{7\pi}{3} , \frac{11\pi}{3} , \frac{13\pi}{3}, \frac{17\pi}{3}, \frac{19\pi}{3} ...[/tex]
Because the its in the 1st quadrant and the 4th quadrant, it is pi/3 and 5pi/3, because it is in a circle, you can just keep adding 2pi (360 degrees) to pi/3 or 5pi/3... but when you divide by 3, it has to be within 0 < x < 2pi
remember that the cos function has a period of 2pi, so it's a repeating cycle -- think of the cos graphs.
so... u divide each answer by 3...
[tex] x = \frac{\pi}{9}, \frac{5\pi}{9} , \frac{7\pi}{9} , \frac{11\pi}{9} , \frac{13\pi}{9}, \frac{17\pi}{9}[/tex]
As you can see, I didnt include 19pi/9 as an answer because it is outside the domain.
seiferseph said:
sin3x=1/2
The thing to remember is that for trig equations, there are potentially an *infinite* number of solutions. This is because trig functions are periodic.
So you must always specify the range you're looking for solutions in. This is usually [tex]0 \leq x < 2\pi[/tex] but not always. So this must be specified.
Assuming that's the range we're going to use, this is the simplest way to solve it :
Think about what angles have sines of half. For sine to be positive, the angle can be in the 1st and 2nd quadrants, so you have [tex]\frac{\pi}{6}[/tex] and [tex]\frac{5\pi}{6}[/tex]. Those are two possible values for 3x, correct ?
Since you're going to be dividing those by 3 to get x, you should take more values for 3x if you want to get all the values in the required range. Since you know [tex]\sin \theta = \sin{(\theta + 2k\pi)}[/tex], where k is an integer, just add [tex]2\pi[/tex] and [tex]4\pi[/tex] to the above values to get all the possible values of 3x.
So you have :
[tex]3x = \frac{\pi}{6}, \frac{5\pi}{6}, (\frac{\pi}{6} + 2\pi), (\frac{5\pi}{6} + 2\pi), (\frac{\pi}{6} + 4\pi), (\frac{5\pi}{6} + 4\pi)[/tex]
and dividing by 3 and simplifying, you get the required solutions in radians within the required range.
ok, thanks to everyone, i got the answers (which i probably could've done) but more importantly know how to do it and why it works. thanks!
  • · Replies 17 ·
