Energy due to a charge is infinite?
The discussion revolves around the concept of energy associated with electric fields generated by charges, particularly questioning whether the energy due to a charge can be considered infinite. Participants explore implications of the conservation of energy in the context of electric fields and the movement of test charges in response to these fields.
  • One participant questions the implications of a test charge moving away from a stationary charge, suggesting that this leads to infinite energy gained from the electric field.
  • Another participant challenges this notion, stating that just because the distance is infinite does not imply that the energy is infinite, prompting a discussion on the general expression for work and its dependencies.
  • Some participants emphasize the need to investigate how much energy is required to accelerate charged versus neutral particles, suggesting a deeper inquiry into the dynamics involved.
  • Several participants calculate the work done using integrals, concluding that the work done does not yield infinite energy, despite concerns about the continuous motion of the test charge.
  • There is mention of the energy associated with the system of two charges, indicating that the energy is not solely derived from the stationary charge but is a property of the entire system.
  • Some participants note that the energy of the charge Q alone is infinite, highlighting a known inconsistency in classical electrodynamics.
  • Concerns are raised about the professor's statement regarding the conservation of energy, with some suggesting it may have been misquoted or taken out of context.
Participants express differing views on the implications of energy associated with electric fields, with some asserting that energy is not infinite while others maintain that the energy of a charge alone can be considered infinite. The discussion remains unresolved with multiple competing perspectives on the topic.
Participants highlight limitations in understanding the energy dynamics involved, particularly regarding the assumptions made about the motion of charges and the definitions of energy in the context of electric fields.
A Dhingra
energy due to a charge is infinite??
hello..
My professor said "Law of conservation of energy is not applicable to waves." This puzzled me a lot and trying to think otherwise i have a doubt regarding energy due to electric field. It seems that if energy due to electric field and magnetic combined, this might turn out to be true for light.
Let us have a charge Q at rest, whose electric field exists in the whole space. If a test charge,q i.e. Q>>q, is placed in this region, then due to repulsion it will move away from the charge Q. It will continue this motion till it is at infinite distance. This suggests that the total energy gained by the charge q from Q is infinite, further suggesting that the energy due to the electric field is not getting used up... i.e. i can bring as many test charges as i want but this repulsion will exist, no matter how much energy the previous one has taken. So how is that so?
What kind of energy is possessed by the electric field created by a charge? Is it never ending, and suggesting that it never got created (may be when the charge or the electric field was formed)? in that sense this need not obey the laws of conservation of energy!
may be what i have asked is very silly, but any help is appreciated..
Thanks in advance.
This is incorrect. Simply because the distance is infinite does not imply that the energy is infinite.
What is the general expression for work? What does the energy depend on besides the distance? What happens if this other quantity goes to 0 and is that the situation here?
Welcome to PF;
Your prof is challenging you.
What you want to investigate is how much energy it takes to accelerate a charged particle compared with a neutral particle.
[Dalespam has shown you the way to challenge the argument you were provided with.]
Work is W=∫F.dx .
So in it if i apply the limits some distance r to ∞, i would get,
W = ∫(kQq/x2) dx = -kQq/x, x from r to ∞,
= -kqQ(1/∞-1/r) = -kQq/r..
this is definitely not ∞.
But I was thinking that the test charge is moving continuously (with non uniform, decreasing acceleration) almost for infinite time. In that case the sum of all the small patches under the curve should have given infinite energy(I was considering kinetic energy, on v-t graph)...but that doesn't seem to be happening...
A Dhingra said:
hello..
As was already pointed out to you(by Dalespam) this process does not render an infinite amount of energy but besides that this energy is not produced by the rest charge Q alone, this energy is assigned to the system of two charges and it is yust the energy recovered from the one used to assemble the two charges.
However there is a problem if you think of the energy of the charge Q alone since this energy is indeed infinite. This is a known problem of electrodynamics and is an indication that classical electrodynamics is not logically consistent unlike Newtonian mechanics which does not suffer from consistency problems.
A Dhingra said:
Work is W=∫F.dx .
Exactly! Well done.
Again, you need to carry out the appropriate integral. However, you seem to think that the area under a v-t graph represents energy. It does not.
Think about what the appropriate integrand is, consider impulse, momentum, and the relationship between momentum and KE. Look at that integrand, is there some part of it that makes you think it might not be infinite? If you can, perform the integral.
You must have misquoted your professor or taken eir words out of context. Law of conservation of energy applies everywhere, except possibly on a cosmological scale. (The latter uncertainty is due to our lack of understanding of gravity, ad hoc inflaton fields, and dark energy.)
Khashishi said:
You must have misquoted your professor or taken eir words out of context. Law of conservation of energy applies everywhere...
Or the prof is using a pedagogical technique hoping to stimulate inquiry, a bit like the famous goldfish problem (why does a goldfish not displace any water?) ... the statement itself looks like an oblique reference to what facenian was talking about.
  • · Replies 22 ·
