What Speed Will the Spacecraft Hit the Moon's Surface?
  • Thread starter Thread starter Azytzeen
The discussion centers on calculating the impact speed of an unmanned spacecraft crashing into the Moon's surface after a malfunction reduces its speed by 30.0 m/s. The spacecraft orbits at an altitude of 40.0 km, and the gravitational constant is given as 6.673 x 10^-11 N*m^2/kg^2, with the Moon's mass at 7.75 x 10^22 kg and radius at 1.74 x 10^6 m. Participants emphasize using energy conservation principles and centripetal force equations to derive the final impact speed.
  • Understanding of gravitational force and energy conservation principles
  • Familiarity with centripetal force equations (Fc = mv^2/r)
  • Basic knowledge of Newton's second law (F = ma)
  • Ability to perform calculations involving mass, speed, and gravitational constants
  • Study energy conservation in gravitational fields
  • Learn how to calculate centripetal force in orbital mechanics
  • Explore the relationship between kinetic energy and potential energy during free fall
  • Practice solving problems involving Newton's laws of motion
Students and enthusiasts in physics, aerospace engineering, and anyone interested in orbital mechanics and gravitational effects on spacecraft.
Azytzeen
An unmanned spacecraft is in a circular orbit around the moon, observing the lunar surface from an altitude of 40.0km (see Appendix F). To the dismay of scientists on earth, an electrical fault causes an on-board thruster to fire, decreasing the speed of the spacecraft by 30.0m/s.
If nothing is done to correct its orbit, with what speed (in km/h) will the spacecraft crash into the lunar surface?
Take the gravitational constant to be 6.673*10^-11 N*m^2/kg^2, the mass of the Moon to be 7.75*10^22, and the radius of the Moon to be 1.74*10^6.
Ok, um, how do I approach this problem? I can't reason it out. Please don't do the problem for me. I really want to learn how to do this, but I just can't figure it out. Thanks in advance.
Great approach.
Now you know that the spacecraft crashes into the moon so you do not need to worry about how it gets to the moons surface.
Now there is a certain amount of energy gained from falling from the spacecraft s orbit to the surface.<-use energy conservation.
The spacecraft also starts out with a certain amount of kinetic energy determined by it velocity and mass. The problem does not state the velocity that the spacecraft has before it is decreased by 30.0m/s. You know though that it was in a stable orbit however.
Have you found the velocity of a spacecraft in a stable orbit before? You have to balance the centripetal force and the centrifugal forces.
After finding the initial kinetic energy and the energy due to falling you should be able to find the speed at which it hits the planet.
Was this too much info?
Hi there,
I understand your frustration with this problem. It can be overwhelming to approach a physics problem without any prior knowledge or understanding. However, let's break it down step by step and see if we can find a solution together.
First, let's identify what we know and what we are looking for. We know that the spacecraft is in a circular orbit around the moon at an altitude of 40.0km. We also know that an electrical fault has caused a decrease in the spacecraft's speed by 30.0m/s. We are looking for the speed at which the spacecraft will crash into the lunar surface.
Next, let's see if we can use any equations to solve this problem. The first equation that comes to mind is the equation for centripetal force, which is Fc = mv^2/r. This equation relates the centripetal force (Fc) to the mass of the object (m), its velocity (v), and the radius of its orbit (r). However, we don't have enough information to directly use this equation.
But, we do know that the decrease in speed is caused by an on-board thruster firing. This means that a force is acting on the spacecraft in the opposite direction of its motion. This force can be calculated using Newton's second law, which states that force (F) is equal to mass (m) times acceleration (a), or F = ma. In this case, the acceleration is the change in velocity (30.0m/s) divided by the time it took for the thruster to fire.
Now, we can use the force calculated from Newton's second law and plug it into the equation for centripetal force, along with the mass of the moon and the radius of the orbit, to solve for the velocity at which the spacecraft will crash into the lunar surface.
I encourage you to try out these steps and see if you can come up with a solution. If you get stuck, don't hesitate to reach out for further assistance. Good luck!
9K
