New Reply
Question about fluid dynamics (calculating concentration)
Share Thread Thread Tools
Feb10-13, 04:27 PM   #1
Hi all,
I have a question about calculating the concentration of continuous air and carbon monoxide flowing through a pipe. If the gas cylinder originally has 20% CO and 80% air and it will be diluted by another gas cylinder of air, how do you account for temperature, pressure, and 'viscosity' of the gases when calculating the concentration in ppm?
Any advice would be appreciated.
Thanks for your help.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Feb10-13, 04:40 PM   #2
cjl
To a reasonable approximation, you can probably assume perfect mixing and get the concentration from that. Do you know the flow rates from both the original source and the diluting gas?
Feb10-13, 05:11 PM   #3
Yeah, I know the flow rates from both so, I can use C1*F1=C2*F2. I'm assuming perfect mixing. Do you know how I could correct for temperature or viscosity?
Feb10-13, 05:33 PM   #4
cjl
Viscosity shouldn't matter if you know the flow rate, and temperature will cause a change in the density (which could change the mass flow rate). I would probably calculate the molar flow rates of each first (based on volumetric flow rate and density), and then the concentration of the resultant mixture should be fairly easy to find.
Feb10-13, 06:40 PM   #5
You know a lot more about this than I do. Thank you for your help! I found the molar flow rate in mol/min. I know this might be obvious, but I can't figure out how to calculate concentration from here. Thank you again!
New Reply
Thread Tools
Similar Threads for: Question about fluid dynamics (calculating concentration)
Thread Forum Replies
Fluid dynamics question Introductory Physics Homework 2
Fluid Dynamics, Calculating viscosity using damping coeffiecient Advanced Physics Homework 0
Calculating friction loss (fluid dynamics)? Classical Physics 0
Fluid Dynamics Question Engineering, Comp Sci, & Technology Homework 1
fluid dynamics question Introductory Physics Homework 0
