For what values is this function continuous
The problem involves determining the values of α for which the function F(x) is continuous at x = 0. The function is defined piecewise, with a specific expression for x ≠ 0 and a value of 0 at x = 0.
  • Participants discuss the need for the limit of F(x) as x approaches 0 to equal F(0) for continuity. There are considerations about the behavior of the function as x approaches 0, particularly regarding the terms involving α and their impact on continuity.
Participants are exploring different aspects of the function's behavior near x = 0, questioning the relevance of certain terms in the expression and discussing simplifications. Some guidance has been offered regarding the significance of the sin and cos terms in the limit process.
There are mentions of previous experiences with similar functions and concerns about the oscillatory nature of the cosine term as x approaches 0. The discussion reflects on the implications of α being even or odd and the potential need for specific constraints on α for continuity.
lmstaples
[itex]F(x) \ = \ (x^{2})^{\frac{\alpha}{2}} \left[ \frac{\alpha sin \left( \frac{1}{x} \right)}{x} \ - \ \frac{cos \left( \frac{1}{x} \right)}{x^{2}} \right] \ if \ x \neq 0[/itex]
[itex]F(x) \ = \ 0 \ if \ x \ = \ 0[/itex]
Question basically says, for what values of alpha is this function continuous
My mind is torn between either: α = 0, for all α or some constriction on α being EVEN or ODD
thanks for any help
You need the ##\displaystyle \lim_{x \to 0} F(x) = F(0) = 0## in order for the function to be continuous.
How do you do that for functions which have "two parts" to them?
Also, as x starts getting close to 0 everything is going to go crazy because of all the dividing by x's.
I remember doing a question a while back which was basically "is f(x) = sin(1/x) continuous at 0 if f(0) = 0?" I believe the answer was no because of sequential continuity?
First, concentrate on the two terms inside the bracket. Can you see a reason to say that one of them makes the other irrelevant?
Next, assuming that ab is defined to mean the positive real value when a > 0 and b > 0, can you see a way to simplify ##\left(x^2\right)^{\frac{\alpha}{2}}## that's valid for α > 0 and all x?
The main difference between the two terms in the brackets are:
1) the use of α in the sin term
2) the cos term is over a higher power of x
Possibly the cos term is irrelevant due to it not depending on α which is what in looking for, for continuity.
Or possibly the sin term is irrelevant as it tends to ∞ slower than the cos term?
The reason as two why it is (x^2)^(α/2) is because it was originally |x|^α
What do you get if you collect them into a single fraction? Compare the two terms in the numerator. Can you see that one of them becomes irrelevant when compared to the other as x tends to 0?
I feel the |x|α form will be the easier to work with.
Sorry in advance for lack of latex, on a mobile.
Combining brackets gives us:
[α(x^2)sin(1/x) - xcos(1/x)]/[x^3]
I can't see how one term is particularly irrelevant.
As for |x|^α: by all means use that notation, I only changed it as that particular function [F(x)] actually came from finding the derivative of another function and I found it easier using the other notation.
If you could explain why that notation would be easier to work with would be helpful :)
Looking back, as x tends to 0 the cos term must become irrelevant.
e.g. If x = 0.000001,
x >> x^2
lmstaples said:
[α(x2)sin(1/x) - xcos(1/x)]/[x3]
It's a little simpler than that: [αxsin(1/x) - cos(1/x)]/x2
What does each of the terms in the numerator do as x tends to 0?
Well the sin term will tend to 0 but the cos term will oscillate like crazy
Right, so you can ignore the sin term. And of course x2 = |x|2. So what do can you reduce the whole expression to?
I believe I got it to reduce to [(x^2)^(α/2 - 1)][-cos(1/x)]
Right, but I still think you're better off with the form [|x|α-2][-cos(1/x)].
You've already described what -cos(1/x) will do as x tends to 0. So what do you need |x|α-2 for the whole to converge to 0?
Would it not converge to 0 for any α >= 2
  • · Replies 40 ·
