Solving Algebra Problem: [3+ x5/3y]/x
  • Thread starter Thread starter Imparcticle
    Algebra Bit
The discussion revolves around simplifying an algebraic expression involving fractional exponents, specifically the expression [3 + x^(5/3)y] / x^(2/3). Participants are attempting to clarify their understanding of the simplification process and the manipulation of terms with exponents.
  • Participants are exploring different methods of simplifying the expression, questioning the correctness of factoring out terms, and discussing the implications of exponent rules. Some are attempting to clarify how certain terms relate to each other, particularly regarding the presence of x^2 in the context of the problem.
The discussion is active, with participants providing various insights and methods for simplification. Some guidance has been offered, but there appears to be confusion regarding the steps taken and the reasoning behind them. Multiple interpretations of the problem are being explored without a clear consensus on the correct approach.
Participants are grappling with the manipulation of fractional exponents and the implications of factoring terms. There is uncertainty about the appropriate steps to take, particularly in relation to the smallest power of x in the expression.
Imparcticle
I'm not sure how to do this:
[3x-1/3 + x5/3y] / x2/3
this is what i did:
[3 + x5/3y ]/ x1/3x2/3
[3+ x5/3y]/x
the answer to the problem is the same as what I have except instead of x^5/3, its x^2.
help.
Of course it is.Put it like that:
[tex]\frac{\frac{3}{x^{\frac{1}{3}}}+x^{\frac{5}{3}}y}{x^{\frac{2}{3}}}[/tex]
Do you see where that x^{2} is coming from...?
Daniel.
Your 1.step, that is, extracting [tex]x^{-\frac{1}{3}}[/tex] from the parenthesis has been done incorrectly.
Try to figure out why.
u can take x^2/3 in factor for the numerator, u will have:
[x^2/3(3x^-1 +xy)]/x^2/3
then u simplify and obtain
3/x + xy
which leads to (3 + yx^2)/x
no.
Your 1.step, that is, extracting from the parenthesis has been done incorrectly.
I don't see it.
how are you factoring a x^2/3 when the smallest power is -1/3 ? if you factor that out, x^5/3 should be x^1/3.
help.
[tex]\frac{\frac{3}{x^{\frac{1}{3}}} + x^{\frac{5}{3}}y}{x^{\frac{2}{3}}} = { \left( \frac{3}{x^{\frac{1}{3}}} + x^{\frac{5}{3}}y \right) \over x^{\frac{2}{3}}}\cdot \frac{x^{\frac{1}{3}}}{x^{\frac{1}{3}}} = \frac{3 + x^2y}{x}[/tex]
I only posted this because I think you're getting more confused by the replies so far. Try to take a lesson from the method I used to simplify (that is, multiplying by 1 is a good idea sometimes!).
  • · Replies 25 ·
10K
