Thread Closed
FIND Nominal interest rate
Share Thread Thread Tools
Mar13-05, 09:03 PM   #1
Question
how do u do this ? Find the nominal interest rate that is equivalent to 18%/a compounded quarterly, if interest is paid monthly?
WOh confusing What do u do?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Mar13-05, 11:09 PM   #2
I'm not really sure if your given is 18%/a convertible quarterly or 18% convertible quarterly, however, i can try to help you in both;
The formula used here should be
[tex]
(1 + \frac{i^{(4)}}{4})^4 = (1 + \frac{i^{(12)}}{12})^{12}
[/tex]
Whatever it is, you are given [tex]i^{(4)}[/tex]. Solve for [tex]i^{(12)}[/tex]
Mar14-05, 09:41 PM   #3
Does this make sense I did all the calculations following an example problem its a little hard to write it out here but I wrote
P(1+0.18/4)^4=P(1+i)^12
and solved for i finding the 12th root of the left side and then subtracting 1
i=0.001478 or 1.478% then to get the nominal rate I multiplied this by 12
so 12*1.478% and got = 17.736%
Therefore 17.736%/a compounded monthly is equivalent to 18%/a compounded quarterly.
IS THIS CORRECT?
Mar15-05, 10:01 PM   #4
ANYONE KNOW IF MY PREVIOUS POSTS ANSWER IS CORRECT ANYONE???
Sep11-10, 01:43 PM   #5
Quote by aisha View Post
Hi there:
Read this lecture and you'll know the answer by yourself:
[PPT]Nominal and Effective Interest rates
(Write it on any search engine and then download the link - Good luck.
Feel free to send back if you cannot get it.
Sep11-10, 03:26 PM   #6
[QUOTE=gmohamed;2876247]
Hi there:
To complete my answer after viewing the lecture I sent you with other references, yes, your answer is correct.
The formula you need to use here is as follows:
(1 + 18%/4)^4 = (1 + i/12)^12
Only i is unknown and you need to figure it out as follows:
Just do simple math, and re-write terms, then, you will find the following answer:
i = 0.1773655395684
You can also reach to the same answer by simply using the equivalent interest rate calculator.
Good luck :)
Thread Closed
Thread Tools
Similar Threads for: FIND Nominal interest rate
Thread Forum Replies
Be Wary of Low Interest Rate Balance Transfers General Discussion 0
how to work out the effective annual rate if you ocmpound 6% nominal for indefinite General Math 3
Interest rate, Differential Eq problem. Calculus & Beyond Homework 6
Interest rate comparison trouble Introductory Physics Homework 4
Annuities: Determining the Interest Rate Introductory Physics Homework 1
