First Order Differential Equations where a<x<b (Intial value?)
The discussion focuses on solving the first-order differential equation given by the expression sqrt(y-x^2y)*dy/dx = -xy, specifically within the interval -1 < x < 1. The solution provided is y = 1/4(2C*sqrt(1-x^2) + C^2 - x^2 + 1), where C is a constant. The participants clarify that the inequality indicates the domain of x for which the solution is valid, and that outside this range, the solution may involve different mathematical functions, such as inverse trigonometric functions.
  • Understanding of first-order differential equations
  • Familiarity with solving differential equations involving inequalities
  • Knowledge of square root functions and their domains
  • Basic concepts of initial value problems in calculus
  • Explore the implications of inequalities in differential equations
  • Learn about initial value problems and their solutions
  • Study the behavior of solutions outside defined intervals
  • Investigate inverse trigonometric functions and their applications in differential equations
Mathematics students, educators, and anyone studying differential equations, particularly those dealing with inequalities and initial value problems.
kafuzz
Hi, I'm having trouble understanding what to do when a First order equation has an inequality at the end of it.
For example : sqrt(y-x^2y)*dy/dx = -xy where -1<x<1
I've solved the differential equation with y = 1/4(2C*sqrt(1-x^2) + C^2 -x^2 +1) where C is a constant.
What do I do with the inequality? Is it an initial value problem?
welcome to pf!
hi kafuzz! welcome to pf! :smile:
kafuzz said:
HI've solved the differential equation with y = 1/4(2C*sqrt(1-x^2) + C^2 -x^2 +1) where C is a constant.
your solution contains √(1 - x2) …
you'll probably find that if |x| > 1, you get a solution with √(x2 - 1), or maybe some inverse trig function :wink:
  • · Replies 52 ·
10K
