| New Reply |
Cart on an inclined slope |
Share Thread | Thread Tools |
| Feb13-13, 09:48 PM | #1 |
Hey guys,
I am trying to figure out which motor to order for a side project of mine. I am trying to push a 1000 pound cart up a 10 degree incline. The cart has four elastomer wheels, and may possible encounter carpeted surfaces. I'm not quite sure what to expect in regards to a coefficient of friction yet on a carpeted surface, but I wanted to check my math a bit to understand if I am approaching this problem correctly: Coefficient of Friction = Cf Required Force = Fr Weight = Fw Force Normal to Slope = Fn = = Cf*Fw*Cos(10) Force Parallel to Slope = Fw*Sin(10) So Fr = [Cf*Fw*cos10] + [Fw*Sin(10)]? Thanks for any help in advance! I just wanted to double check if I am doing my statics correctly. |
| Feb17-13, 06:22 AM | #2 |
The motor power depends on how fast you want to go up the slope eg power = force * velocity. The static force gives you the minimium torque required.
This equation.. Force Parallel to Slope = Fw*Sin(10) is correct but I'm not so sure about the friction term. I think what you have used.. Cf*Fw*Cos(10) .. is the friction between wheels and ground. For the driving wheels that force is actually acting up the slope not down it. I think you also need to find the rolling resistance instead. I'm not sure if that's typically the same. Edit: I checked and they are very different. If the wheel doesn't slip no power is dissipated overcoming friction between tyre and ground. You need to use the rolling coefficient instead. |
| Feb17-13, 02:35 PM | #3 |
Thanks for the response. The coefficient of friction method seemed like it was returning really high values.
Is the COF based on a surface to surface contact and the rolling resistance is based on a point to surface contact? It seems like that would results in some more reasonable values. |
| New Reply |
| Thread Tools | |
Similar Threads for: Cart on an inclined slope
| Acceleration due to gravity - cart pushed up an inclined air track (discussion) | Classical Physics | 3 | ||
| A cart with mass M was released at the top of a rough inclined plane | General Physics | 0 | ||
| acceleration and velocity of cart travelling down an inclined plane. | Introductory Physics Homework | 4 | ||
| Find Average Velocity of cart rolling down the slope. | Introductory Physics Homework | 3 | ||
| [SOLVED] Cart on an inclined ramp, with rebound | Introductory Physics Homework | 4 | ||
