Is the kinetic energy of an electron the same in all frames reference?
The discussion revolves around the kinetic energy of an electron and its behavior across different frames of reference, touching on concepts from special relativity and wave-particle duality.
  • The original poster attempts to relate kinetic energy to wavelength and questions whether kinetic energy is invariant across frames. Other participants explore the implications of being in a co-moving frame and the resulting kinetic energy.
Participants are actively questioning the assumptions regarding kinetic energy and its invariance. Some guidance has been offered regarding the relationship between kinetic energy and momentum, as well as the implications of special relativity on these concepts.
There is a discussion about the validity of the original poster's equation for kinetic energy and the implications of length contraction and reference frames. The conversation also hints at the complexity of the matter-wave relation and its dependence on the frame of reference.
LoadedAnvils
Is the kinetic energy of an electron the same in all frames of reference?
I think that the kinetic energy of an electron is E = hc / λ. However, I am not sure: I got this from searching Google rather than learning it myself.
I think that, due to length contraction, the wavelength is different in both frames, and hence it is not the same in all frames of reference. However, I am not sure about this.
What is the kinetic energy of an electron if you are in a co-moving frame with it? i.e., if you are "running" alongside an electron at the same speed as it, what speed is it going relative to you? Does it have any kinetic energy?
Zero.
If I considered classical kinetic energy then I would say that the kinetic energy is 0. However, I know that this is not the case.
Can you be more clear because I am not sure to which conclusion you are leading me towards.
LoadedAnvils said:
Zero.
But it is the case. There's no such thing as a privileged reference frame. This means that if you are in the same frame as an electron its kinetic energy is zero. However, from another frame of reference its kinetic energy will not be zero. This tells you that the kinetic energy of an object is not frame-invariant. This is true even in special relativity. In special relativity, it's the magnitude of the four-momentum that is invariant: ##(E/c)^2 - p^2 = (mc)^2##, where ##E## is the total energy.
So what about the matter-wave relation, then? The matter-wave relation (the de Broglie relation) is ##\lambda = h/p = (hc)/(pc)##. Now, we know ##pc = \sqrt{E^2 - (mc^2)^2}##, where E is again the total energy, from relativity. We can also show that ##E = KE + mc^2##. With some manipulations you can then show
$$pc = KE \sqrt{1-2\frac{mc^2}{KE}}$$.
This means that your assumption that ##KE = hc/\lambda## isn't quite true. It's only (approximately) true if the particle's kinetic energy (in the lab frame) is much greater than its rest energy.
But, let's make that approximation anyways - basically, let's say we're in the non-relativistic limit. The problem you are having, then, is that if kinetic energy is not invariant, then it would seem like wavelength is not invariant also. Should wavelength be invariant? Since you posted this in the homework forum, I'll have to try and guide you to the answer.
Consider, say, a free (massive) particle moving in one dimension. The corresponding Schrödinger equation is
$$\hat{p}^2 \psi(x,t) = -\frac{\hbar^2}{2m} \psi(x,t) = i\hbar \frac{\partial \psi(x,t)}{\partial t}$$.
What's the solution to this equation? What sets the particle's energy - and hence, wavelength? What would happen if we put the particle in some potential?
  • · Replies 87 ·
  • · Replies 30 ·
