How do I find an unknown weight ?
  • Thread starter Thread starter mushhhy
    Weight
The discussion focuses on calculating the unknown weight of a car in a lab experiment involving collisions on a frictionless rail. The initial weight of the car without batteries is established at 0.986 kg, and the weight of three Rayovac cells is calculated to be 2.94 N. Key calculations include acceleration, force, kinetic energy, and impulse upon collision, with specific formulas applied throughout. The final weight of the car with the cells is determined to be 0.56 N, using the updated mass and acceleration values.
  • Understanding of Newton's laws of motion
  • Familiarity with basic physics formulas (F = ma, KE = 1/2 mv²)
  • Knowledge of units of measurement (N, kg, m/s²)
  • Ability to perform calculations involving averages and conversions
  • Study the principles of momentum and impulse in collisions
  • Learn about energy conservation in mechanical systems
  • Explore the effects of mass on acceleration and force
  • Investigate the role of friction in real-world applications
Students in physics courses, educators teaching mechanics, and anyone involved in experimental physics or engineering applications related to motion and forces.
mushhhy
Here is the problem that was set up as a lab experiment.
We ran a car on a Rail (assumed to be frictionless) and collided it with another (stationary) car. There were three trials and I have gathered thwe average of the the
Next we added three rayovac cells to the car and repeated the same process.
I will provide the work already performed (i do not think it is correct) but here goes.
the weight of the car without batteries is 985.5g = 0.986kg
the impacted car car is posistioned at 100cm on the rail. Xi =100cm = 1m
average Xf = 38 cm = .37m
Ti =0, average Tf =4.25s
We are to find the following:
Here goes The problem states to find the following
1. Acceleration 5. Work
2. mass 6.the weight of three rayovac cells placed on the object
3. Force 7. momentum with and without cells
4. KE 8. Impulse upon collision
This is the work I have completed so far.
1.
a = (Vf - Vi/t), Vi = 0, Vf = d/t = -0.63m/4.25s = -0.15m/s
a = (-0.15m/s)/4.25s =-0.035m/s^2
2.
m = w/g = (0.986kg) / (9.8m/s^2) = 0.1N
3.
F = m x a = (0.1N) (-0.035m/s^2) = -3.5 x 10^-3 (N)(m/s^2)
4.
KE = (1/2)mv^2 = (1/2) (0.1N) (-0.15m/s)^2 = 11.25 x10^-4 J
5.
W = (FcosO)X = (3.5 x 10^-3) (-.62m) = -2.17 x10^-4 J
I do not know how to calculate the weight of the car with the cells.
The process is the same with 3 runs the average time and distance are
Xi = 100cm = 1m, Xf = 51.67cm, = .52m
Ti = 0 Tf = 3.25s
I have no idea how to do the rest of this exercise. I am willing to do the work but I need some direction o:) . Any help at all will be greatly appreciated. I need to know how to do this work for a test in my next class meeting. :cry:
THANKS
!!!6. The weight of the three Rayovac cells placed on the object can be calculated using the formula:Weight = Mass x Gravity, where Mass is the mass of the object and gravity is 9.8 m/s2. So, the weight of the three Rayovac cells would be:Weight = 3 x 0.1 x 9.8 = 2.94 N.7. Momentum with Cells = Mass x Velocity = 0.1 x (-0.15) = -0.015 kg m/s.Momentum without Cells = Mass x Velocity = 0.986 x (-0.15) = -0.149 kg m/s.8. The impulse upon collision can be calculated using the equation: Impulse = Change in Momentum. The change in momentum in this case is the difference between the momentum with and without cells. Therefore, the impulse upon collision is:Impulse = -0.134 kg m/s.
To find the unknown weight, we need to use the formula F = ma, where F is the force, m is the mass, and a is the acceleration. In this experiment, we know the acceleration from the first part of the problem (a = -0.035m/s^2), and we can also calculate the force (F = -3.5 x 10^-3 (N)(m/s^2)).
Now, we can rearrange the formula to solve for the mass: m = F/a. Plugging in the values we know, we get: m = (-3.5 x 10^-3 (N)(m/s^2)) / (-0.035m/s^2) = 0.1kg. This is the mass of the car without batteries.
To find the weight, we need to multiply the mass by the acceleration due to gravity (g = 9.8m/s^2): w = mg = (0.1kg) (9.8m/s^2) = 0.98N. This is the weight of the car without batteries.
To find the weight of the car with the three Rayovac cells, we can follow the same process. The only difference is that the acceleration will be different, since the car now has more mass due to the added cells. We can calculate the new acceleration by taking the average of the three trials from the second part of the experiment: a = (-0.52m/s)/(3.25s) = -0.16m/s^2.
Now, we can use the same formula as before to find the new weight: w = mg = (m) (-0.16m/s^2) = (-3.5 x 10^-3 N)(-0.16m/s^2) = 0.56N. This is the weight of the car with the three Rayovac cells.
To find the force, momentum, KE, impulse, and work with the added cells, we can use the same formulas as before, but with the new values for mass and acceleration. For example:
Force: F = ma = (0.1kg) (-0.16m/s^2) = -0.016N
Momentum: p = mv = (0.1kg) (-0.52m/s) = -0.052kgm/s
KE: KE = (1
9K
