New Reply
What would E field addition be if Gauss's law was different
Share Thread
Feb17-13, 05:05 PM   #1
What if Gauss' Law was
div(E)=q2/eps0
Then if we had two point charges, how could we calculate the resultant E field at an arbitrarily point? Obviously superposition would not work anymore, so how could it be done mathematically?
This is essentially a math question
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Feb17-13, 05:15 PM   #2
Recognitions:
Gold Membership Gold Member
Did you stop to check if it was first dimensionally correct before proceeding? The units for the real gauss's law pertain to a physically interpretable / measurable quantity.
Feb17-13, 10:18 PM   #3
math doesn't care about units
Feb17-13, 10:41 PM   #4
Recognitions:
I'm trying to understand your question but I don't quite follow? The right side seems to have units of charge squared divided by farads per meter, but the lefts units are completely different. What is this supposed to mean?
Feb18-13, 05:01 AM   #5
Mentor
Quote by Curl View Post
Physics does.
You have received your answer: what you wrote does not have the correct units, so there is no answer to your question. It would be like asking "how long would it take a ball to fall 7 gallons"
Feb19-13, 12:14 AM   #6
I guess another way to ask this is to say if a particle of special type of matter had the property that it created a vector field given by
F=(c*m^2/r°r)*r/|r| where m is the mass of the particle,
then if I have two particles, each of mass m, one at the origin and one at x=1, then what would be the resultant field F at an arbitrary point r0 ???
Feb19-13, 02:26 AM   #7
I think you already answered your question regarding the force, since you explicitly stated it.
However, if I'm understanding you correctly, I think you might be getting at the concept of linearity and the superposition of fields. Is your question what the resulting field would be if it varied as the square of the sum of all the masses/charges in some way? If so, you likely could not use Gauss's law at all, since it's a sum which assumes that the total field can be produced by summing each up piece of field, which in turn assumes a sum over each charge/mass. If the field produced by each infinitesimal source cannot be added linearly to produce the net overall field (that is, it is not independent of the other charges/masses present), then this sum does not give you the total flux, and therefore cannot give you the total mass/charge. In other words, by summing the field, you are no longer summing the total charge/mass, since they are not linearly related.
To answer your original question, if the divergence of the electric field were proportional to the square of charge, then nothing would really change other than we'd probably treat the fundamental charge as its squared counterpart (and some units would need to be added or modified). It would still be linear in superposition, though.
(Note: This is intuitive reasoning. Correctness not guaranteed.)
Mar8-13, 11:40 PM   #8
Quote by cwilkins View Post
I don't quite follow this part, how did I explicitly state it? I stated that the masses are at different locations.
Mar9-13, 12:15 AM   #9
You gave the expression for the force in your post. The values you gave could have been plugged into it.
New Reply
Similar discussions for: What would E field addition be if Gauss's law was different
Thread Forum Replies
Gauss's Law with non-uniform E-field Introductory Physics Homework 46
Gauss's Law with NONuniform E field Introductory Physics Homework 5
Proof of closure under addition and multiplication in a field Calculus & Beyond Homework 8
Vector addition in electric field Introductory Physics Homework 14
Gauss's Law / Electric Field Introductory Physics Homework 1
