Diffnt suppliers, same composition (AlTiB) yielding 2 different Grains
  • Thread starter Thread starter selseg
    Composition
The discussion revolves around the performance differences observed in two samples of AlTiB grain refiners used in aluminum casting, despite both having similar compositions as indicated by certificates. Participants explore factors influencing grain quality and discrepancies in the Ti:B ratio.
  • One participant notes that the new AlTiB sample does not yield good grains, raising questions about other influencing factors beyond composition.
  • Another participant suggests that impurities or grain size might affect the performance of the new sample.
  • A participant questions whether the 0.3% unaccounted composition difference could significantly impact grain quality.
  • Concerns are raised about the discrepancy in the Ti:B ratio, with one participant proposing that the supplier's specifications might be in mol% while the analysis is in wt%.
  • Another participant emphasizes the need for additional information about the system and application to assess the significance of the 0.3% difference.
  • One participant recommends seeking expert help to clarify the cause of the observed differences.
  • A suggestion is made to investigate granulometric distribution and examine the materials under a microscope to assess particle sizes.
Participants express differing views on the significance of impurities and the impact of the Ti:B ratio discrepancy. The discussion remains unresolved regarding the exact cause of the performance difference between the two samples.
Limitations include the lack of specific information about the application and system conditions, which may influence the interpretation of the 0.3% composition difference.
selseg
I work at an Aluminum sheet casting plant, we use AlTiB as the grain refiner for our cast products.Ti:B ratio as indicated on certificates is 5:1 .We recently received a new consignment of AlTiB from another supplier in India.The certificates from our new supplier show that the The AlTiB we bought is of the same composition as the old one.However the new one doesn't yield good grains even when the rod is fed into the molten metal at faster rates.I decided to melt samples of the two Grain Refiners and determine their compositions with AAS.I made the following observations the two samples had the same composition.Interestingly the Ti: B Ratio was 20:1.Ti composition was about 10% whiles that of Boron was about 0.5%The only noticeable physical difference between the two refiner rods is the lustre, the new rod has a dull surface appearance.
QUESTION 1 : Both samples have the same composition , why don't I get good grains with new sample ?
Is there any other factor that influences AlTiB refiner properties aside composition ?
QUESTION 2 : How come Ti:B ratio for both samples(as determined by me after melting and analysing) is 20:1 rather that 5:1 as indicated on the product certificate.
The answer to your first question is that the reason could be either impurities, or grain size, although the latter may not be valid if you fuse completely the material.
As to the second question, provider's specifications are probably in mol % and your analysisi is in wt%. The molar mass of Ti is roughly 4 times larger than that of B.
Thank you very much Alkim ,It makes a lot of sense. But still on the first question , below are the results from the two samples .less than 0.3% of the composition is not accounted for from the analysis .Is that enough impurity to make such a huge difference ?
Al --88.441 --89.443
Si --0.1040 --0.099
Fe --0.2160 --0.185
Cu --0.0122 --0.0099
Mn --0.0070 --0.005
Mg --0.0005 --0.0005
Cr --0.0026 --0.002
Zn --0.0020 --0.0036
Ti --10.345 --9.5798
Ni --0.0173 --0.0116
Pb --0.0170 --0.015
V --0.0636 --0.0084
B --0.5331 --0.419
SUM --99.762 --99.782
It is hard to answer whether those 0.3 % are important or not without having any additional information about your system, concentrations, applikcation, etc. Depending on that, 0.3 % could be considered a huge amount or just insignificant traces. What's more, the problem could be even in the apparently small differences in the analysis of the two materials. If you are sure the problem is in the new material you can just reject it as a row material. However, if you do need to clarify the real cause for the difference and you can allow it I recommend you to consider obtaining expert help from a university or a technological center.
Thank you very much Alkim ,I will do just that
You are wellcome. By the way, I have just found this article. A quick look at it has made me think that probably it is a matter of granulometric distributuion. Try to have a look at both materials using a microscope (after etching the samples with an acid if necessary). The difference in their lusters might be an indication of different particle sizes.
Regards
11K
