Find Min of f(x,y,z)=x^8+y^8+z^8 on x^4+y^4+z^4=4
The minimum of the function f(x,y,z) = x^8 + y^8 + z^8 on the surface defined by the constraint x^4 + y^4 + z^4 = 4 occurs at the point (x,y,z) = ((4/3)^(1/4), (4/3)^(1/4), (4/3)^(1/4)). This result is derived using the method of Lagrange multipliers, leading to the equations 8x^7 = λ4x^3, 8y^7 = λ4y^3, and 8z^7 = λ4z^3. The minimum value of the function at this point is approximately 3.266, while if any of the variables x, y, or z equals zero, the minimum value of the function is 0.
  • Understanding of multivariable calculus and optimization techniques
  • Familiarity with the method of Lagrange multipliers
  • Knowledge of gradient vectors and their properties
  • Ability to solve polynomial equations
  • Study the method of Lagrange multipliers in greater detail
  • Explore optimization of functions under constraints
  • Learn about gradient descent and its applications in optimization
  • Investigate the implications of zero variables in multivariable functions
Students and professionals in mathematics, particularly those focusing on calculus and optimization, as well as researchers working on constrained optimization problems.
jenc305
Find the points at which the function f(x,y,z)=x^8+y^8+z^8 achieves its minimum on the surface x^4+y^4+z^4=4.
I know
8x^7=(lamda)4x^3
8y^7=(lamda)4y^3
8z^7=(lamda)4z^3
x^4+y^4+z^4=4
Case1: x not equal to 0, y not equal to 0, and z not equal to 0
I get 3(4th root of 4/3 to the eigth)?
I'm I doing this right?
Are you sure this doesn't belong in the homework section?
Since grad f always points in the direction of fastest increase of f, to get to a minimum, you should go in the exact opposite direction. Of course, if you are required to stay on the surface x4+ y4+z4= 4, you can't do that. What you can do is go opposite to the component tangent to the surface. That works until you get to a point where grad f is perpendicular to the surface and has no component tangent- that's when you are at the minimum point on that surface.
If you let g(x,y,z)= x4+ y4+ z4 then the surface is a level surface of g- and grad g is perpendicular to the surface: we must have grad f parallel to grad g which means grad f= &lamda; grad g for some number &lamda;. That's the idea of the LaGrange multiplier.
Yes, your formulas are correct!
If x is NOT 0, then, dividing the first equation by 8x3, we have
x4= (1/2)λ. Similarly for y not 0 and z not 0: which means that, whatever &lamda; is, x= y= z so the x4+ y4+ z4=
3x4= 4 so x= y= z= (4/3)1/4. The value you give is the value at that point- you were asked for the points themselves.
However, it is not necessarily true that "either x,y,z are all 0 or they are all non-zero"! If x= 0, y= 0 but z is NOT 0, then z= 41/4 so (0, 0, 41/4) is a possible place for a minimum. If x= 0 but y and z are not 0, then as before we can show that y= z so 2y4= 4 and (0, 21/4,21/4) is possible minimum. The same is true of "y and z 0 but not x", "y 0 but not x or z", etc.
Yes, you are on the right track. To find the minimum of a function on a given surface, you can use the method of Lagrange multipliers. This involves solving a system of equations where the gradient of the function is equal to a scalar multiple of the gradient of the constraint (in this case, x^4+y^4+z^4=4).
In this case, we have the following equations:
8x^7 = λ4x^3
8y^7 = λ4y^3
8z^7 = λ4z^3
x^4 + y^4 + z^4 = 4
To simplify the equations, we can divide both sides by 4:
2x^7 = λx^3
2y^7 = λy^3
2z^7 = λz^3
x^4 + y^4 + z^4 = 1
Now, we can solve for λ in terms of x, y, and z:
λ = 2x^4 / x^3 = 2x
λ = 2y^4 / y^3 = 2y
λ = 2z^4 / z^3 = 2z
Since λ is the same for all three equations, we can equate them:
2x = 2y = 2z
This implies that x = y = z. Substituting this into the constraint equation, we get:
3x^4 = 4
x = (4/3)^(1/4)
Therefore, the minimum of the function f(x,y,z) = x^8 + y^8 + z^8 on the surface x^4 + y^4 + z^4 = 4 occurs at the point (x,y,z) = ((4/3)^(1/4), (4/3)^(1/4), (4/3)^(1/4)). Plugging this into the function, we get the minimum value of f(x,y,z) = 3(4/3)^(2/4) = 3(4/3)^(1/2) ≈ 3.266.
Note that this is the minimum value when x, y, and z are not equal to 0. If any of them is 0, then the minimum value of the function would be 0.
