Is There a Ring Homomorphism for All Unital Rings in Evaluation Homomorphism?
  • Thread starter Thread starter Monobrow
Monobrow
Is it true that for any unital ring (not necessarily commutative), that we have a ring homomorphism for all a = (a_1, ...,a_n)\in R, from R[X_1,...,X_n] → R given by sending a polynomial f to f(a)? I have only ever seen this for fields. I cannot think of any possible reason it would be false for general rings but I just wanted to make sure.
No, it is not true.
Take for example the Weyl-algebra. This is W=\mathbb{Z}<a,b> / (ab-ba-1). So it is the algebra generated by a and b such that [a,b]=1.
Anyway, consider the polynomial ring W[X,Y]. There does not exist a homomorphism T such that T(X)=a and T(Y)=b.
Indeed. If it would exist, then T(XY)=ab and T(YX)=ba. But XY=YX, and thus ab=ba. So it fails.
The problem is that polynomial rings have an inherent commutativity which is not compatible with noncommutative rings.
Very related to your question is the question about free objects of commutative R-algebras (with R commutative). The polynomial ring is a free object for this algebra. But as soon as you allow the algebras (and R) to be noncommutative, then it is not a free object anymore.
The free object in such algebra is given by R<X_1,X_2,...,X_n>. These are polynomial rings in which the X_i and the X_j do not commute. In fact, there are no relations between the X_i and the X_j at all.
The property you mention in the OP fails for polynomial rings in noncommutative setting, but it holds for the free algebra I mentioned above (in commutative or noncommutative setting).
Thanks a lot. It was the non-commutative case I was worried about and it's good to see why it doesn't work.
I think you need to be a little careful even to define polynomial rings and evaluation over non commutative R. I believe one usually assumes R[X1,...,Xn] is a ring in which the elements Xi are in the center. Then, given an element a of R which may not commute with the coefficients of a given polynomial f, one has two evaluations of f at a, left evaluation and right evaluation. Nonetheless these two maps are useful; in particular there is a left and a right division algorithm, and two remainder theorems, allowing you to compute the remainder of both left and right division of f by (X-a).
This is all discussed on pages 37-41 of Fundamental Concepts of Higher Algebra by A.A.Albert.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
