Integrating by Volume: Calculating Solid Volume Using Disk/Washer Method
The problem involves calculating the volume of a solid obtained by rotating the region bounded by the curves y=(1/4)(x^2), x = 2, and y = 0 about the y-axis using the disk/washer method of integration.
  • Mixed
  • Participants discuss the application of the disk/washer method and the necessity of integrating with respect to y instead of x. There are attempts to clarify the setup of the problem and the reasoning behind using different methods.
Some participants have provided guidance on the correct axis of rotation and the need to consider both the outer and inner radii when using the washer method. There is an ongoing exploration of the implications of the setup and the calculations involved.
Participants express uncertainty about the need to multiply the volume calculation by 2 and question the interpretation of the area being revolved. There is a mention of a hollow space in the region that affects the volume calculation.
kmr159
1. Find the volume for the solid obtained by rotating the region bounded by the given curves about the specified line. y=(1/4)(x^2), x = 2, y = 0, about the y-axis
2. Use the disk/washer method of integration to find the volume
3. When I try to solve this problem using small changes in x (dx) I get the wrong answer. Method: Take integral from 0 to 2 of a function for the area of a circle.
∫ from 0 to 2 : 2[(∏)*((x^2)/8)^2] dx → ∫ from 0 to 2 : (∏x^4)/32 → ∏/5
I do not see why I need to use the washer method as using the disk method encounters no hollow space
the answer given is 2pi
Please tell what I'm doing wrong.
Thanks
I'm not comfortable with the washer method, that's why I solved the problem with small change in the x axis.
You appear to be rotating around the x-axis. The problem asks you to rotate around the y-axis. Then there is a hollow space between x=0 and x=sqrt(4y). The part between x=sqrt(4y) and x=2 is the filled in part.
If you're supposed to rotate around the y-axis and use the disk/washer method, then you need to integrate with respect to y, not x. Rewrite [itex]y = \frac{1}{4}x^2[/itex] in terms of x. Use x = 2 to find the upper limit of integration in terms of y. Also, this integral should be multiplied by π, not 2π.EDIT: Beaten to it. ;)
Oh, not by much. Both posts have valuable information.
Thanks for all your help
I am rotating about the y-axis
I am multiplying the entire ∏r2 portion by 2 because my equation only finds the area one half of the resultant solid
to find r I divided (1/4x2) by 2 to find the radius of my circles.
thanks again
No, you don't need to do that! The problem, as you stated it, says to
The resulting area of the region lies only in the 1st quadrant, and that is the only region that is revolving around the y-axis. There is no need to "multiply by 2."
I don't understand what you are saying here. You need to use the washer method, so you have to find two radii, normally notated as R and r. The integrand would contain R2 - r2, and pi is outside of the integral.
  • · Replies 27 ·
  • · Replies 16 ·
