Kinematics of a particle with drag
The discussion revolves around the kinematics of a particle experiencing drag, specifically in the context of a Java 2D object simulation. Participants explore how to calculate the object's velocity and position over time given an initial velocity and position, while also considering the effects of drag during motion.
  • One participant presents a model where acceleration is proportional to the square of velocity, leading to a derived expression for velocity as a function of time.
  • Another participant suggests that the position can be updated using the derived velocity without needing to re-derive it, proposing a time-stepping approach for position updates.
  • A later reply indicates that the integration for position should consider the constant initial velocity, leading to a logarithmic expression for position.
  • One participant challenges the idea of separating velocity components, stating that they are coupled in one-dimensional motion unless additional forces are considered.
  • Another participant expresses uncertainty about the validity of separating components and notes issues that arise when the initial velocity is large.
  • Discussion includes a suggestion to update velocity using a formula that incorporates drag directly, questioning the use of a general formula for step-by-step updates.
Participants do not reach a consensus on whether the velocity components can be separated, and there are differing opinions on the best approach to implement drag during motion. The discussion remains unresolved regarding the most effective method for updating position and velocity.
Some participants express uncertainty about the assumptions made in their calculations, particularly regarding the treatment of drag and the coupling of motion components. There are also unresolved mathematical steps related to the integration and application of drag forces.
chimpz
(this is all in context to a java 2d object and is not homework related)
I have an object with velocity [itex]v[/itex] and position [itex]x[/itex].
Its acceleration is directly proportional to velocity squared ie [itex]a=k v^{2}[/itex].
Given the objects initial velocity [itex]u[/itex] and its initial position [itex]x_{0}[/itex] how would i work out its velocity and position at time [itex]t[/itex]?
I have tried integrating:
[itex]a = \frac{dv}{dt} = kv^{2}[/itex]
[itex]\int^{v}_{u} v^{-2} dv = \int^{t}_{0} k dt[/itex]
[itex]\frac{1}{u} -\frac{1}{v} = kt[/itex]
[itex]v = \frac{1}{\frac{1}{u} - kt}[/itex]
tbh I got a lot further while writing this post than I did trying to work it out before
trying to get the new position:
[itex]\int v^{-2} dv = \int k dt[/itex]
[itex]-\frac{1}{v} = kt[/itex]
[itex]v = \frac{dx}{dt} = -\frac{1}{kt}[/itex]
[itex]\int^{x}_{x_{0}}1\:dx=\int^{t}_{0}-\frac{1}{kt}dt[/itex]
[itex]x-x_{0}=-\frac{1}{k}\left[\:ln|t|\:\right]^{t}_{0}[/itex]
But you can't [itex]ln|0|[/itex] :/
So, without bounds:
[itex]x=-\frac{1}{k}ln|t| + c[/itex]
Now I'm stuck.
How would I update the location?
Also, how would I implement drag while the engines were on?
Part of my code:
Code:
public void update(double delta) {
	if (engines) {
		double dv = Math.sqrt(2 * powerToWeight * delta);
		Vector2f temp = dir.copy(); //dir is the direction of the engine's force
		temp.scale(dv);
		velo.add(temp);
		double dx = dv * delta * 2 / 3;
		temp = velo.copy();
		temp.scale(dx);
		loc.add(temp);
		// TODO add drag
	} else {
		velo.i = (float) (1 / ( (1 / velo.i) - drag * delta ));
		velo.j = (float) (1 / ( (1 / velo.j) - drag * delta ));
		// TODO update location
Pleased with myself for using the itex tags for the first time :D
Edit: could this be considered a hw-type question?
You can integrate this to get the position, there is no need to derive v(t) again.
If you do it in time steps: ##x += v \delta t##
Add this as acceleration, try to derive v(t) again. If that does not work, do it in time steps.
I forgot [itex]u[/itex] was a constant :P ok so:
[itex]\int^{x}_{x_{0}}1\;dx=\int^{t}_{0}\frac{1}{\frac{1}{u} - kt}dt[/itex]
[itex]x-x_{0} = -\frac{1}{k}\;[\;ln|\frac{1}{u} - kt|\;]^{t}_{0} <br /> = -\frac{1}{k}(\;ln|\frac{1}{u} - kt|\; - \;ln|\frac{1}{u}|\;) = -\frac{1}{k}\;ln|1-ktu|[/itex]
so I'm guessing i do this separately for each component of the vector :)
Thank you for pushing me xD
In general, you cannot separate those components, they are coupled. Without other sources of acceleration, the motion happens in one dimension only, so you can rotate that x in the appropriate direction.
O .. i was pretty sure you could separate the [itex]i[/itex] and [itex]j[/itex] components.
but a problem occurs when [itex]u[/itex] is a large positivehere is part of my update method now when there are no other forces on the object:
Code:
if (velo.i != 0) {
	loc.i += (float) (Math.log(1 - dragConst * delta * velo.i) / dragConst);
	velo.i = (float) (1 / ((1 / velo.i) - dragConst * delta));
if (velo.j != 0) {
	loc.j += (float) (Math.log(1 - dragConst * delta * velo.j) / dragConst);
	velo.j = (float) (1 / ((1 / velo.j) - dragConst * delta));
Wait... if you update it step by step, why do you use the general formula?
What about velo.i = velo.i - velo.i*sqrt(velo.i^2 + velo.j^2)*k?
I hope I got the angles right.
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 17 ·
  • · Replies 19 ·
